03DMshee Posted March 28, 2012 Report Share Posted March 28, 2012 hey guys have a quick question about the height of my banshee raising 2 inches in the front after the following were replaced... powedercoated following... A Arms works springs hubs rotors spindels tie rods parts replaced A Arm bushings front bearings I also went to a set of hiper wheels..4/1 offset everything is freshly greased but i havnt physicly ridden the bike yet nor have i jounced the suspension much but my question is this something that will settle down a bit after it is riden for a couple days? also my shocks are works shocks and measure 14.5 eye to eye any help would be appriciated as i have a trip this weekend id like to rip this thing.... Quote Link to comment Share on other sites More sharing options...
Azryll Posted March 28, 2012 Report Share Posted March 28, 2012 Is the Preload on the shocks in the same spot from when you got the springs powder coated? Quote Link to comment Share on other sites More sharing options...
03DMshee Posted March 28, 2012 Author Report Share Posted March 28, 2012 Is the Preload on the shocks in the same spot from when you got the springs powder coated? they look exactly the way they did when they left..haha... my other banshee with stock suspension is only a half inch shorter eye to eye but sits 1.5 inches lower... maybe the new wheels being differant offset are not letting bike drop as much? i came from factory wheels to 4/1 hiper...any thoughts on that? Quote Link to comment Share on other sites More sharing options...
421alkybanshee Posted March 29, 2012 Report Share Posted March 29, 2012 A arm mount bolts are too tight. x2 Quote Link to comment Share on other sites More sharing options...
03DMshee Posted April 3, 2012 Author Report Share Posted April 3, 2012 x2 thanks guys! loosened the bolts and it dropped an inch on its own...tightened everything to factory specs..all good thanks again! Quote Link to comment Share on other sites More sharing options...
