jdog Posted March 27, 2012 Report Share Posted March 27, 2012 (edited) I have a banshee and it smoke a lot what can i do to fix it Edited March 27, 2012 by jdog Quote Link to comment Share on other sites More sharing options...
Poolman Posted March 27, 2012 Report Share Posted March 27, 2012 I have a banshee and it smoke a lot what can i do to fix it What makes you think anything is wrong with it ? Did it just all of a sudden start smoking allot ? --------- Maybe you made a Goof on your ratios with the last batch of Gas you mixed. Quote Link to comment Share on other sites More sharing options...
cline Posted March 27, 2012 Report Share Posted March 27, 2012 (edited) From my experience and from what I understand the smoke is caused from running your bike real rich. If you are trying to clean it up do a plug chop and see where you stand. If your plugs are way to dark and you want to rejet then I will suggest what I see others say all the time which is to only change one thing at a time. Then rejet starting to work your way down and check plugs to make sure you don't go to lean. As I see Larrys shee tell people all the time, "plugs are cheaper than pistons " Edited March 27, 2012 by cline Quote Link to comment Share on other sites More sharing options...
