G-Torque Posted March 26, 2012 Report Share Posted March 26, 2012 I saw a kit online that lowers 3 1/2 " from the front and its adjustable on the back... What I don't find convinient is that is not recomended for jumps . I'm not a pro with jumps but i love doing weelies.. Any of you guys had ever use this ? I'm afraid that when I pop the weelie one of those jaws could go out of place . OI want him to have that street drag look and be able to do weelies. I don't thing an extended swing ARM on the back would do any good for weelies... I just to make him lower for traction on street . Check out this item I found on eBay: YAMAHA BANSHEE FRONT & REAR LOW LOWER LOWERING KIT ATV QUAD Link: http://www.ebay.com/itm/YAMAHA-BANSHEE-FRONT-REAR-LOW-LOWER-LOWERING-KIT-ATV-QUAD-/220983826601 (Sent from eBay Mobile for Android) Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted March 27, 2012 Report Share Posted March 27, 2012 all it does is move the lower shock mount outward closer to the wheel in the front. for the rear, is just lowers the linkage. do not get them. Take a torch and heat the spring until it is where you want it then through water on it..... Quote Link to comment Share on other sites More sharing options...
sidewayz Posted March 27, 2012 Report Share Posted March 27, 2012 I saw a kit online that lowers 3 1/2 " from the front and its adjustable on the back... What I don't find convinient is that is not recomended for jumps . I'm not a pro with jumps but i love doing weelies.. Any of you guys had ever use this ? I'm afraid that when I pop the weelie one of those jaws could go out of place . OI want him to have that street drag look and be able to do weelies. I don't thing an extended swing ARM on the back would do any good for weelies... I just to make him lower for traction on street . Check out this item I found on eBay: YAMAHA BANSHEE FRONT & REAR LOW LOWER LOWERING KIT ATV QUAD Link: http://www.ebay.com/itm/YAMAHA-BANSHEE-FRONT-REAR-LOW-LOWER-LOWERING-KIT-ATV-QUAD-/220983826601 (Sent from eBay Mobile for Android) Quote Link to comment Share on other sites More sharing options...
sidewayz Posted March 27, 2012 Report Share Posted March 27, 2012 Ok.... Im confused. First off those front kits are a death trap! The rear are ok ive used one for racing and it worked fine. If you wanna pop wheelies just soften the rear shock and run the back tires lower on air. If anything id shorten the swingarm to do weelies.lol Quote Link to comment Share on other sites More sharing options...
Glenyboy Posted March 27, 2012 Report Share Posted March 27, 2012 R1 or r6 shocks with a set a arms that allow you to adjust the camber. You won't be wanting to jump on a lowered setup though!! Quote Link to comment Share on other sites More sharing options...
G-Torque Posted March 27, 2012 Author Report Share Posted March 27, 2012 Thanks guys... I was affraid of that in the front links ...Cause it looks like as soon the quad goes up that link could get up straight and the weelies won't be the problem .THE PROBLEM IS GONA B ON THE LANDING.lol. I ask cause I wasn't sure if the shocks would keep them down with its presure but I just realize that as soon it droops down now the a-arms would have more free play . Not safe at all... Quote Link to comment Share on other sites More sharing options...
