Colby Posted March 26, 2012 Report Share Posted March 26, 2012 Those bolts forward of the drain plug... what do they do? This is the second banshee i have had that has the exact same bolt leaking. What can be done to fix the problem ? Quote Link to comment Share on other sites More sharing options...
Hilarious Posted March 26, 2012 Report Share Posted March 26, 2012 (edited) Those bolts forward of the drain plug... what do they do? This is the second banshee i have had that has the exact same bolt leaking. What can be done to fix the problem ? they hold the engine cases together..... there is a hole above in the middle of the cases, you most likely have something leaking thru there.... what kind of liquid? Edited March 26, 2012 by Hilarious Quote Link to comment Share on other sites More sharing options...
Surfrjag Posted March 26, 2012 Report Share Posted March 26, 2012 those are holding your cases together. must not have enough yamabond between the cases in that area. is it tranny fluid? might have to split them to fix it properly. Or its gas leaking from your carb and running through the hold thats in the cases and looks like it coming from somewhre else. Quote Link to comment Share on other sites More sharing options...
coon Posted March 26, 2012 Report Share Posted March 26, 2012 i just blew my bottom end up yesterday no crank oil...only thing i can notice is a small wet spot by them bolts so im wondering the same thing..i believe its crank oil but there is not a full case of it there. Quote Link to comment Share on other sites More sharing options...
Colby Posted March 26, 2012 Author Report Share Posted March 26, 2012 (edited) its tranny fluid.. well if im gonna have to split the cases, might as well do my 4 mil build .. Edited March 26, 2012 by Colby Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted March 27, 2012 Report Share Posted March 27, 2012 its tranny fluid.. well if im gonna have to split the cases, might as well do my 4 mil build .. If you do split the cases take the time to clean them really well. Dirty contaminated cases are the biggest leader to leaks. - Jared Quote Link to comment Share on other sites More sharing options...
Colby Posted March 27, 2012 Author Report Share Posted March 27, 2012 If you do split the cases take the time to clean them really well. Dirty contaminated cases are the biggest leader to leaks. - Jared thanks! I will be using your bottom end walkthrough soon! Quote Link to comment Share on other sites More sharing options...
