blowit Posted March 25, 2012 Report Posted March 25, 2012 We have stock of our ever popular billet shift star. For the new guys, we designed a fully billet shift star with improved geometry over a modified stocker, we improved the neutral stop to eliminate the annoying neutral hang up when shifting between 1st and 2nd, and lengthened the shift pins so the shift claw can no longer slip off the shift star and ruin your day. Improved shifting performance and increased reliably. We provided a small tweak to this latest revision of stars with adjustments to the neutral stop area. Some found it hard to find neutral so we back cut that just a touch more to improve it even more! These have been popular and hard to keep in stock so get yours while you can! http://www.mullengineering.com/sc/store.php/products/yamaha-banshee-yfz-rz-billet-shift-star-shaft-drum-transmission-race-drag-sand-shifting-hard-online Brandon Mull Engineering Quote
Phelps Posted March 25, 2012 Report Posted March 25, 2012 stock setup, or did you cut any for us N down no 6th guys? looks like a nice product Quote
blowit Posted March 25, 2012 Author Report Posted March 25, 2012 stock setup, or did you cut any for us N down no 6th guys? looks like a nice product We are going to follow right back up in about 3 weeks and take a look at the override needs. I would invite you guys to PM or email us with preferred requirements and reservations for them. I think there was some concern over the small market for them. I would like to know which designs are most needed. Quote
Buckwheat Posted March 26, 2012 Report Posted March 26, 2012 Does the engine have to be disassembled to install this? Quote
okbeast Posted March 26, 2012 Report Posted March 26, 2012 Does the engine have to be disassembled to install this? Clutch side yes Quote
BigRed350x Posted March 26, 2012 Report Posted March 26, 2012 Does the engine have to be disassembled to install this? Do you even own a banshee? lol Quote
blowit Posted April 2, 2012 Author Report Posted April 2, 2012 are these heat treated ? Yes, these are heat treated. Quote
252wheelieking Posted April 2, 2012 Report Posted April 2, 2012 Does the engine have to be disassembled to install this? Quote
moledigger Posted April 3, 2012 Report Posted April 3, 2012 Ordered mine. Will this star work with a shiftpro roller bearing kit? I have a modded star I did my self with a shiftpro kit and neutral is very hard to find still. Quote
blowit Posted April 3, 2012 Author Report Posted April 3, 2012 The star works great with the shift pro and we even designed a detent roller bearing that installs on the detent arm for a lot less money. However, we have been told by a few that using the shift pro spring can cause them to jump gears so we recommend using the stock detent arm spring. Finding neutral is an issue that is based on a few design flaws in the Banshee trans. Quote
joee20002 Posted April 3, 2012 Report Posted April 3, 2012 The star works great with the shift pro and we even designed a detent roller bearing that installs on the detent arm for a lot less money. However, we have been told by a few that using the shift pro spring can cause them to jump gears so we recommend using the stock detent arm spring. Finding neutral is an issue that is based on a few design flaws in the Banshee trans. i would like one for the override if you get them going Quote
wfobasheeboy Posted April 3, 2012 Report Posted April 3, 2012 I have one of mull shift star & I love it ! Quote
Buckwheat Posted April 3, 2012 Report Posted April 3, 2012 Do you even own a banshee? lol Yes. The one I own now is my second. I've never been into the engine on either one. Quote
