BryanF Posted March 25, 2012 Report Share Posted March 25, 2012 I went to remove my chain last night and in doing so noticed that with the transmission in Neutral the front sprocket would barely turn. When the sprocket did turn it took alot of force to get it to move. I am really new to this whole thing and am really still learning the ropes of repairs. Does anyone have any helpful hints as to what the issue may be? Thank you all Quote Link to comment Share on other sites More sharing options...
Surfrjag Posted March 25, 2012 Report Share Posted March 25, 2012 maybe it wasnt in neutral? how much force are you talking? Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted March 25, 2012 Report Share Posted March 25, 2012 Chain on or off? Quote Link to comment Share on other sites More sharing options...
BelleauCarl Posted March 25, 2012 Report Share Posted March 25, 2012 If your sure in neutral maybe output shaft bearing going bad Quote Link to comment Share on other sites More sharing options...
BryanF Posted March 26, 2012 Author Report Share Posted March 26, 2012 Chain was off and it was definitely in Neutral. It took 2 hands and a lot of twisting to get the sprocket to move. I have considered the output shaft bearing, but my concern is if there is something staying engaged in the tranny when it is in Neutral. Quote Link to comment Share on other sites More sharing options...
BelleauCarl Posted March 26, 2012 Report Share Posted March 26, 2012 And you ride the bike like that? When you push the bike in neutral should be hard to push to? Could be a broken shift fork too, either way its in bottom end case. Maybe open bottom leaving top end in place. Quote Link to comment Share on other sites More sharing options...
BryanF Posted March 26, 2012 Author Report Share Posted March 26, 2012 And you ride the bike like that? When you push the bike in neutral should be hard to push to? Could be a broken shift fork too, either way its in bottom end case. Maybe open bottom leaving top end in place. No sir I haven't ridden the bike yet. Doing a full tear down before I get on it and ride. Its my first Banshee and I want to check it all out before taking off. In Neutral it seems easy to push. Not any harder than my wife's Blaster. Loaded and unloaded it in my truck no problem. So I will check the output shaft bearing first then move on to the shift fork. Thank you very much Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted March 26, 2012 Report Share Posted March 26, 2012 No sir I haven't ridden the bike yet. Doing a full tear down before I get on it and ride. Its my first Banshee and I want to check it all out before taking off. In Neutral it seems easy to push. Not any harder than my wife's Blaster. Loaded and unloaded it in my truck no problem. So I will check the output shaft bearing first then move on to the shift fork. Thank you very much If you are doing a full tear down before you get on it and ride, why are you concerned at this point? You are going to be splitting the cases and checking everything out anyway, so if something is wrong you will find it then... Quote Link to comment Share on other sites More sharing options...
BryanF Posted March 26, 2012 Author Report Share Posted March 26, 2012 If you are doing a full tear down before you get on it and ride, why are you concerned at this point? You are going to be splitting the cases and checking everything out anyway, so if something is wrong you will find it then... We didn't intend on splitting the case. Looks like we may have to. I am more curious as to what to look for if we split the case. Kinda look for some starting points is all. Like I said before I am new to all this. Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted March 26, 2012 Report Share Posted March 26, 2012 We didn't intend on splitting the case. Looks like we may have to. I am more curious as to what to look for if we split the case. Kinda look for some starting points is all. Like I said before I am new to all this. Get a clymers manual and read it. Bigred350 has a awesome bottom end was through as well. It's a lot easier then you would think.I found it, it's in the technical info section. That's one of the best walk throughs I have ever seen. I can't get the link to work. Quote Link to comment Share on other sites More sharing options...
BryanF Posted March 26, 2012 Author Report Share Posted March 26, 2012 Get a clymers manual and read it. Bigred350 has a awesome bottom end was through as well. It's a lot easier then you would think.I found it, it's in the technical info section. That's one of the best walk throughs I have ever seen. I can't get the link to work. That is a damn fine idea. Hadn't actually considered that. Thank you! I am such a noob! Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted March 26, 2012 Report Share Posted March 26, 2012 When you pull clutch cover and be sure the kicker idler spins freely as it's on other end of output shaft Quote Link to comment Share on other sites More sharing options...
cline Posted March 27, 2012 Report Share Posted March 27, 2012 That is a damn fine idea. Hadn't actually considered that. Thank you! I am such a noob! Heres the link he was talking about and its an excellent visual guide. http://bansheehq.com/forums/index.php?showtopic=140912 Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted March 27, 2012 Report Share Posted March 27, 2012 Get a clymers manual and read it. Bigred350 has a awesome bottom end was through as well. It's a lot easier then you would think.I found it, it's in the technical info section. That's one of the best walk throughs I have ever seen. I can't get the link to work. There is a link to it in my signature. Hope that helps. - Jared Quote Link to comment Share on other sites More sharing options...
BryanF Posted March 31, 2012 Author Report Share Posted March 31, 2012 So we decided to split the case on my Banshee. Turns out that the bushing that secures the gear wheel for 2nd gear had slipped out of the gear and was pressing against the snap ring that keeps the gear separated from the others. Basically the trans wouldn't truly release into neutral. After a 4 dollar fix I am back in action. Quote Link to comment Share on other sites More sharing options...
