headlights and brake light?
Koba
What year is your bike? Newer shees came with light/brake light. The bike I have had a regular light but later added the working brake light to it. What you will have to do is see if someone clipped the wires for your headlight/tail light and re route those wires. Whip out the manual and start wire searching, hope there's a chance they just un plugged it. Just look for snipped wires and test with a volt meter to confirm. Good luck
so when i got my bike it didnt have headlights but still has the factory switch. Idunno if i have wires for it still or not. what should i do about both tail light and head lights?
Well if you say that you don't know if you have wires for it or not, and the TORS has been removed this means that someone has obviously been in the wire harness at least unplugging stuff. If it went any further than is up to you to check, because some guys modify their harness to their liking. You never know, if your bike came without head and tail lights, it might be wired to not accept them anymore. You need to ensure that the harness is still set up to run head and tail lights by verifying your harness against the diagram. If so great, if not try the for sale section for a cheap used good one, try one of the site sponsors, or fix the harness yourself to accomidate lights. Ensure that you have a voltage regulator. Then check the for sale section or F.A.S.T. for head and tail lights and you are good to go. In the tech info thread there is banshee electrical FAQ. Heres the link so you have a diagram and the link to FAST. Good luck.
http://bansheehq.com/forums/index.php?showtopic=133650
http://www.farmandsandtoys.com/
Edited by cline
  • 2 weeks later...
