DirtDiggler69 Posted March 23, 2012 Report Share Posted March 23, 2012 I saw another post mentioning ditching the coolant Rezzie , if I'm running a .020 over stock bore and stock stroke , and I'm jetted on the rich side ( to protect the motor ) can I ditch the Rezzie? I'd prefer to , to clean things up as much as possible . Quote Link to comment Share on other sites More sharing options...
LawDog Posted March 23, 2012 Report Share Posted March 23, 2012 I saw another post mentioning ditching the coolant Rezzie , if I'm running a .020 over stock bore and stock stroke , and I'm jetted on the rich side ( to protect the motor ) can I ditch the Rezzie? I'd prefer to , to clean things up as much as possible . Loose it. but id remove it the way u should just in case u need it. i dont know anyone that runs a rez bottle. cool heads, tor system and rezzie are the first things u get rid of Quote Link to comment Share on other sites More sharing options...
2strokenit Posted March 23, 2012 Report Share Posted March 23, 2012 I've heard of people moving the rezzie to under the front plastics to help with cooling. Does this really help, I can't see how? Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted March 23, 2012 Report Share Posted March 23, 2012 I've heard of people moving the rezzie to under the front plastics to help with cooling. Does this really help, I can't see how? All the rezzy does is keep the coolant from getting on the ground and makes it available to be drawn back in when it cools down. It has no effect on the cooling or temp the bike runs at. Just zip tie the hose that goes from the radiator to the rezzy to the frame and cut it off at the bottom of the frame.Top off the radiator and warm up the bike, whatever pukes out is overfill. Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted March 23, 2012 Report Share Posted March 23, 2012 I run the hose by my exhaust so if it starts to puke it'll go on the exhaust and I'll be able to smell it and see the smoke Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted March 23, 2012 Report Share Posted March 23, 2012 Loose it. but id remove it the way u should just in case u need it. i dont know anyone that runs a rez bottle. cool heads, tor system and rezzie are the first things u get rid of Who told you to get rid of a "cool head?" Quote Link to comment Share on other sites More sharing options...
sidewayz Posted March 23, 2012 Report Share Posted March 23, 2012 Who told you to get rid of a "cool head?" Keep the boost bottle and ditch the cool head..... Lol. Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted March 23, 2012 Report Share Posted March 23, 2012 Keep the boost bottle and ditch the cool head..... Lol. Damn it, I knew I was going at this banshee thing all wrong. Quote Link to comment Share on other sites More sharing options...
LawDog Posted March 24, 2012 Report Share Posted March 24, 2012 Who told you to get rid of a "cool head?" Thanks loco for pointing out my mistake. What i ment to say is ditch the rezzie and boost bottle, and change to a cool head. That is the first things you do when u get a banshee. And just like the other guys said just take the lines and zip tie them down the frame. Quote Link to comment Share on other sites More sharing options...
