G-Torque Posted March 23, 2012 Report Share Posted March 23, 2012 Just bought a shee and the guy that had it before rebuild top end with wiseco ... He change the thumb throtle to twist and never could get him running wright... When start up it seems to be misfiring and not reaching power band ... I took it home and first thing I did was replace plugs and fuel ... Still same... I look at the carbs in the sync window and notice they cross the carb sync cilinders ... The left on right and right on left ... I took them out ... Straight them up ... And did the sync ... Now they open together but quad won't start at all ... It has tomey T - 5 for exhaust. Do I need some special jettings to get this thing running wright ? Also T.O.R.S. is missing ... I saw the plug but box not there... Is there anything else I should do ??? Quote Link to comment Share on other sites More sharing options...
dirtydownunder Posted March 23, 2012 Report Share Posted March 23, 2012 stock toomey jetting for sea level at around 70f is 280 main, stock pilot, air screw at around 2 turns. with the airbox and no lid. if you running pods maybe try 290 first. Quote Link to comment Share on other sites More sharing options...
ticktock Posted March 23, 2012 Report Share Posted March 23, 2012 25 pilot 280 main should be good. Might be a tad rich. I would get 290 280,270 jets. And go from there My other shee is T-5, 280 and runs great Adam Quote Link to comment Share on other sites More sharing options...
tuck1371 Posted March 24, 2012 Report Share Posted March 24, 2012 Depending on how much you kicked it trying to start it with the slides reversed, plugs could be fuel fouled. I just went through all this with my banshee. I pulled the plugs, stood the bike up on the rear grab bar, and manually worked the kicker until I couldn't see any fuel being blown out of the plug hole. Just make sure you're not flooded out, throw a fresh set of plugs in, check the idle adjustment screws, and try to get her to fire again. Good luck! Quote Link to comment Share on other sites More sharing options...
shakar Posted March 24, 2012 Report Share Posted March 24, 2012 imo dont buy anyone of the overprice socalled jetkits...........hit up a site sponser and get yoursself like 250 to 300 and a 27 1/2 pilot, also check what needle you have........ goodluck Quote Link to comment Share on other sites More sharing options...
