am i lean?
jeff05
I have a 4mil crank 40over vitos superstock pistons some porting 18cc domes pro circuit pipes 30mm okos. i was running my stock carbs and it ran fine but i thought it was not running at full poteintal so i put these on there jetted with 160 mains starts fine but when I go wide open it is flat and seems like i loose a cylinder let off the gas a hit it again and it pulls for a second and does it again,Im running 112 octane race gas open air box
If your floats are'nt adjusted propper, You will starv the bike for fuel. I have done that before... It sounds like thats what happening. Orrrr it could be Bad Plug Caps, another issue i had, Once from 8000+ rpm, i would drop a cyclinder because i had a bad spark plug cap. Once i put on 2 brand new caps. The bike never ran better!!
I am also running the OKO 30mm carbs but have never had a problem with them. I heard some guys on here bashing them so I did a search and found that for some guys they had a problem running the bowls dry which sounds like you may be experiencing the same effect. Theres more than one thread on here about the OKO's but I could only find this one real quick. If you search you might find out better info and pm some of the guys that had the problem to find out how they solved it. Heres the link to the discussion I found. Good luck
http://bansheehq.com/forums/index.php?showtopic=129402
