4mil crank into drag ported 350 cyl
possum
ok then back on track you need to know what crank your going to use. IF you do a pop up piston IT MIGHT WORK. any builder worth a shit can tell you if they will work or not if you measure your top down exhaust and transfers i can even run them and see what you end up with.. most times the transfers may jump to 132 ish and the exhaust may bump to just under 200. with a lil fiddlin with base gasket thickness you might get them to work. if noone else wants to help do some measurin and let me know.
I would personally advise against it unless you wanna go for broke and weigh 40lbs. I would have to do more with the exhaust and still super tight and end up with a razor for a power band due to the change in xfer due to the crank change. I would personally recommend a different set of cylinders for that build.
However, if you are stuck on them, we have, in the past, machined the bottom of cylinders to cheat this and custom machine the head to work. This was before Cubs were the rage though. You can get to that point of diminishing returns.
Mull Engineering
