252wheelieking Posted April 26, 2012 Report Share Posted April 26, 2012 If you have .060 squish that is generally more than we run but not bad if its just a play bike. We usually run around .040-50 give or take .005 . If it is cranking 150 without ever being ran then dont worry about it. It would be 10 or 20 more with a warm broken in motor. A 421 usually runs a 12 to 20 thous gasket depending on the builder. Other than squish clearance, what will change between using a .012 & .020 base gasket? Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted April 26, 2012 Report Share Posted April 26, 2012 interesting ,make sure you have cub domes cut for a blaster piston Quote Link to comment Share on other sites More sharing options...
252wheelieking Posted April 26, 2012 Report Share Posted April 26, 2012 (edited) interesting ,make sure you have cub domes cut for a blaster piston Ok I have 22cc cub domes that was cut for a 421 cub, but I have a .020 base gasket. I thought I suppose to use a .012 base gasket. My concern is how much will my performance change from the change of port timing also? Edited April 26, 2012 by 252wheelieking Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted April 27, 2012 Report Share Posted April 27, 2012 you wont be able to feel it,the only time it comes into play is porting goals and engine set-up,if you have a desired squish your builder likes to use and he ported the cylinders with a certain gasket on the wheel stick to it Quote Link to comment Share on other sites More sharing options...
252wheelieking Posted April 27, 2012 Report Share Posted April 27, 2012 you wont be able to feel it,the only time it comes into play is porting goals and engine set-up,if you have a desired squish your builder likes to use and he ported the cylinders with a certain gasket on the wheel stick to it Thanks sleeper06....I did my homework by researching on here(BHQ) & figured out why my builder sent me the .020 base gasket. He didnt explain to me why he runs the .020 base gasket instead of the .012. Reason I was questioning it is because, im not the type to just go with a set-up just because someone said so. I like to learn as much as possible about my build & understand the reason for the combination of parts. Hope that makes sense. Quote Link to comment Share on other sites More sharing options...
vulvafan537240 Posted May 2, 2012 Report Share Posted May 2, 2012 Thanks sleeper06....I did my homework by researching on here(BHQ) & figured out why my builder sent me the .020 base gasket. He didnt explain to me why he runs the .020 base gasket instead of the .012. Reason I was questioning it is because, im not the type to just go with a set-up just because someone said so. I like to learn as much as possible about my build & understand the reason for the combination of parts. Hope that makes sense. how much longer til yours is finished? Quote Link to comment Share on other sites More sharing options...
252wheelieking Posted May 7, 2012 Report Share Posted May 7, 2012 (edited) how much longer til yours is finished? Im going to install topend in the morning & do squish, compression & leakdown test. If everything checks out fine tomorrow, I will be riding it this weekend....I pray all goes well...I have had enough bad luck with my banshee Edited May 7, 2012 by 252wheelieking Quote Link to comment Share on other sites More sharing options...
vulvafan537240 Posted May 7, 2012 Report Share Posted May 7, 2012 Im going to install topend in the morning & do squish, compression & leakdown test. If everything checks out fine tomorrow, I will be riding it this weekend....I pray all goes well...I have had enough bad luck with my banshee Make a build thread. Everybody likes to see new builds and I want a ride report on this one Quote Link to comment Share on other sites More sharing options...
