421 cub comp
What's your squish?
What thickness base gasket? .012 is what most 421's run. You didn't use a stock. 030 gasket did you?
Also a dumb question. They are cub alky domes right?
i got the gasket and domes from jhon sand toyz told him what i was doing and he sent me domes and a gasket not sure on gasket thicknest
If you have .060 squish that is generally more than we run but not bad if its just a play bike. We usually run around .040-50 give or take .005 . If it is cranking 150 without ever being ran then dont worry about it. It would be 10 or 20 more with a warm broken in motor. A 421 usually runs a 12 to 20 thous gasket depending on the builder.
My 421 jumped up 25psi after a few days of riding. Roughly 3 hours worth of riding. Also make sure you break it in With lots of throttle movement. Lots of WOT!! Push those rings out!!
