extended carb tops..........
hey guys just got a pair of those adjustable carb tops from fast racing, is there any trick to installing these? like can they go past full throttle or will they just max out inside the carb? any input is appreciated!
also im running 35mm pwk's
i was looking into these as well as the ez springs but it says they are not for PWK carbs. maybe they will still work but i didnt wanna buy them if they were made for another brand of carb.
if you find out they do work like me know cause i will be picking up a set! :cheers:
im pretty sure when i was talking to jeff i told him the carbs i'm running, i could be wrong tho, ill have to check the site to see if theres any info
unscrew the existing adjusters on your existing carb tops and put the longer ones in.
I had to install a set of these to be able to adjust the slides to where they would open all the way.
I ran out of adjustment with the shorter adjusters and the oem throttle.
I use Jeff's lighter springs, longer tops as well as the metal idle screws in my pwk-35's. All good and only a few bucks. wootrock.gif
you guys know if the light springs would work on 35pwks?
That's what im running. You can also cut 2 rings off the regular springs and stretch them as well.
