notsed Posted March 14, 2012 Report Share Posted March 14, 2012 so i did the test and it looks like my bore is to big for a stock head at 65.5, also i got a reading of .078 but at the tip its at around .039. my question is what should i do? theres no builders around here or anyone who i would trust to cut my stock head. i know if i get a cool head it will fix my dome area issue, but what about the squish? i used .020 base gaskets, so do i need to get custom domes made? im running a 350 dune port on pump with 145 comp and +4 at 600 asl Quote Link to comment Share on other sites More sharing options...
notsed Posted March 14, 2012 Author Report Share Posted March 14, 2012 well i did it 3 times, i get that little pinch at the end in both cylinders. im pritty sure im doing it right ive done it before. my problem is how do i make it tighter without raising compression? should i just get a cool head and go from there? trying not to waste money. why would the squish be so loose in the first place? i need someone to point me in the right direction of how to fix it. thanks Quote Link to comment Share on other sites More sharing options...
Josh Z Posted March 14, 2012 Report Share Posted March 14, 2012 What size bore are your cyls?? if you are at a 66 or bigger then you need a big bore set up.. I am almost wondering if that is the little crimp on the end... I love my cool head set ups and I would recommend having a set of domes cut for every engine that is no longer (stock)... call a site sponsor and have them set it up. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted March 15, 2012 Report Share Posted March 15, 2012 my problem is how do i make it tighter without raising compression? Shave the head then have the cut the combustion chamber larger. Quote Link to comment Share on other sites More sharing options...
