4mildkue Posted March 13, 2012 Report Share Posted March 13, 2012 Has anyone every ran a pingle with stock bowls on alky Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted March 13, 2012 Report Share Posted March 13, 2012 You are wanting to run alky on stock carbs? Quote Link to comment Share on other sites More sharing options...
bigboybanshee Posted March 13, 2012 Report Share Posted March 13, 2012 I'm sure they have...but more than likely ran a pump Quote Link to comment Share on other sites More sharing options...
4mildkue Posted March 13, 2012 Author Report Share Posted March 13, 2012 No I have 38 kehin but my problem is with the billet bowls there giving me about pouring gas out the vent hose but when I put the stock bowls on I don't have that problem Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted March 13, 2012 Report Share Posted March 13, 2012 You have beat this topic into the mud and never really given the full situation. What size dumps? What size mains? What size needle/seat? Are you 100% sure the floats are set correct? Are you 100% sure that the floats werent hanging up on the inside of the bowls on the billet bowls? Are you 100% sure you have a gravity carb? Are you 100% sure you have a pump carb? You have asked 5 differet questions all pertaining to this same issue yet you never give/have enough info for anyone to tell you WTF you actually have going on.. Without details your questions are USELESS. Quote Link to comment Share on other sites More sharing options...
4mildkue Posted March 13, 2012 Author Report Share Posted March 13, 2012 Everything is set right man the damn the rips and everything its just when I put the bowls on there it pours out the vent hose I'm new to alky and the the floats where sticking and I fix that and my carbs don't require the pump rdz verted the to alky for me Quote Link to comment Share on other sites More sharing options...
bigboybanshee Posted March 13, 2012 Report Share Posted March 13, 2012 The bowls aren't the problem, your floats aren't set correctly. Fix that, no more overflow. It's just that simple. Quote Link to comment Share on other sites More sharing options...
dmrhottie Posted March 13, 2012 Report Share Posted March 13, 2012 The bowls aren't the problem, your floats aren't set correctly. Fix that, no more overflow. It's just that simple. ........................id get the opinion of phelps. Quote Link to comment Share on other sites More sharing options...
RadarRacing Posted March 13, 2012 Report Share Posted March 13, 2012 The bowls could be the problem if your floats rub. Quote Link to comment Share on other sites More sharing options...
VR350 Posted March 14, 2012 Report Share Posted March 14, 2012 If the floats aren't rubbing on the bowls (very common) then your floats aren't set right. the reason it comes out your vents is becuase there is no overflow in billet bowls. the stock bowls have an overflow tube. Quote Link to comment Share on other sites More sharing options...
camatv Posted March 14, 2012 Report Share Posted March 14, 2012 crappy billet bowls dont have overflows. i know a guy who can install them andi highly recomend them on any carb. might just save a motor ya never know. hey if the stock bowls fit and work then i say run it obviously and obvious to many many others on here your not really asking a question? your stating an opinion?? im guessing?<>?><> Quote Link to comment Share on other sites More sharing options...
