dmfisher71 Posted March 11, 2012 Report Share Posted March 11, 2012 ok my trials are pretty tight at times..with some pretty decent hilll climbs,, but i also have some that are long and straight.... what would be the better kit to get more low end power...but still wind out pretty high... my options are: option 1) just my standard motor, stock crank, 65mm bore stock or milled head option 2)the Athena 392 big bore kit stock crank option 3) http://www.ebay.com/itm/YAMAHA-BANSHEE-YFZ350-STK-LONG-ROD-CRANK-WISECO-PISTONS-/140587353571?pt=Motors_ATV_Parts_Accessories&hash=item20bba8c5e3&vxp=mtr again this would be a 65mm bore stock cylinders pipes will be either dmc 916, fmf fattys, or older fmf gold series my cylinders no are completely virgin (but need bore) no porting.... will be running stock carbs. Quote Link to comment Share on other sites More sharing options...
SandmanPNW Posted March 11, 2012 Report Share Posted March 11, 2012 Out of the 3 options posted, I would stick with #1 Quote Link to comment Share on other sites More sharing options...
Glenyboy Posted March 11, 2012 Report Share Posted March 11, 2012 Never heard good things about option 2. Quote Link to comment Share on other sites More sharing options...
Hellacious Posted March 11, 2012 Report Share Posted March 11, 2012 (edited) Of what you mentioned I'd go #1....but: 4th option...If you wanted the best bang for your buck. Speak with some of the site sponsers and tell them what you want and just have a nice port job done. 5th option....What I'm going to do. Go ahead and go 4mil with ported stock cyls. Edited March 11, 2012 by Hellacious Quote Link to comment Share on other sites More sharing options...
ClayAiken Posted March 11, 2012 Report Share Posted March 11, 2012 1 Quote Link to comment Share on other sites More sharing options...
rjdgriff Posted March 11, 2012 Report Share Posted March 11, 2012 Yeah what you are REALLY going to want is a 421 serval... LOTS down low and still has plenty up top!!! Quote Link to comment Share on other sites More sharing options...
coryv4 Posted March 11, 2012 Report Share Posted March 11, 2012 ok my trials are pretty tight at times..with some pretty decent hilll climbs,, but i also have some that are long and straight.... what would be the better kit to get more low end power...but still wind out pretty high... my options are: option 1) just my standard motor, stock crank, 65mm bore stock or milled head option 2)the Athena 392 big bore kit stock crank option 3) http://www.ebay.com/itm/YAMAHA-BANSHEE-YFZ350-STK-LONG-ROD-CRANK-WISECO-PISTONS-/140587353571?pt=Motors_ATV_Parts_Accessories&hash=item20bba8c5e3&vxp=mtr again this would be a 65mm bore stock cylinders pipes will be either dmc 916, fmf fattys, or older fmf gold series my cylinders no are completely virgin (but need bore) no porting.... will be running stock carbs. dont listen to any of these retards for trail i would recomend a 14dmx with oofs and a -4 swingarm. Quote Link to comment Share on other sites More sharing options...
Dicklez Posted March 11, 2012 Report Share Posted March 11, 2012 dont listen to any of these retards for trail i would recomend a 14dmx with oofs and a -4 swingarm. Just go front wheel drive. Quote Link to comment Share on other sites More sharing options...
CruelSoul Posted March 12, 2012 Report Share Posted March 12, 2012 Get a 4 stroke for trails or a little blaster like I did I love my blaster for trails, it's great on fuel I have vitos strocker crank with hot rods connecting arm +3,aggressive trail port,the head has been modded,33mm carb,uni filter,procircuit pipe it is barely even heard it pretty quiet unless you really get on it also have a +3 swinger incase I wanna climb a bit with it btw I paid 400 for it the way it looks in the pic. Quote Link to comment Share on other sites More sharing options...
WINDYCITYJOHN400 Posted March 12, 2012 Report Share Posted March 12, 2012 If your keeping the stock head and crank, I figure budget is the prime factor. With that in mind, your best bang for the buck is to put a set of Vito's "super stock" pistons in the motor with a set of FMF fatty pipes. You can see an example of what that can do if you look in the dyno section under "Random dyno runs" (it's bumped to the top for ya) I know those dyno runs have some things you don't, but it shows you what you can grow into as you get more money down the road. It gives you a cheap easy map to power. We've used it on a few bikes and done dyno testing to confirm. Hope that helps. Quote Link to comment Share on other sites More sharing options...
jlsparky7 Posted March 12, 2012 Report Share Posted March 12, 2012 #1 with a 4 mill.... Quote Link to comment Share on other sites More sharing options...
themechanic Posted March 12, 2012 Report Share Posted March 12, 2012 i went for the athena setup, i took some good pics of the cyls too. athena picts its good for the price. as you can see the ports are a great deal better than stock. Quote Link to comment Share on other sites More sharing options...
