rhino head o-rings blowing
katt68
99 banshee with a rhino cool head..keeps blowing the orings around the pistons.....ideas?
Nobody can help you unless you are extremely specific about your problem as well as your banshee and where you ride. You need post up everything.......
-mods to your bike
-where you were riding
-temp, elevation
-what carbs, main jet size, pilot jet size, needle position
-what events led up to the blown O-ring
-two stroke oil used and at what ratio
-tors removed or not
If you aren't specific about your problem you'll either get no response or 10,000 different responses which neither are going to get you anywhere. These guys on here are really sharp but you have to help them help you. To much information = Good Not enough information = Bad I would at least start with at least the items I suggested then if the experts require more they will ask you. Try this and your results will be much better.
Edited by cline
-mods to your bike
-temp, elevation
Just need the standard info to help you most of the time.
Mods to the bike
Temp, elevation
Carb info is very help full too.
too much compression, warped head, improper installation, wrong O rings... list goes on and on
^^^^^X2^^^^^
the bike is bored out 1 size over, normal riding in Canada, nova scotia...
running i belive 21 domes,
new plugs, was working fine until recently started blowing the seals...i suspect the head warped? any way to tell?
tors is removed.... was told to run 50:1 ratio of the amsoil sythetic oil.....
please advise
when you replaced them did you use the brown Orings just like that came out of it? by that i mean are you using the kit sold for the rhino head? if so i would think the head is warped. what are you using to hold the orings in place and do you have a pic of a old blown oring?
i did not use a kit, i went to a hydraulic shop and fitted o rings that fit, i did use Viton ones(brown), what is the best way to see if the head is warped?
A straight edge and a feeler gauge. Take measurements in about every direction you can. If your not sure how to do this take it to a shop.
