No-lines Posted March 8, 2012 Report Share Posted March 8, 2012 Hi Guys The clutch arm the engine on my banshee keeps lifting up and rubbing the carb bottom It does this if the engine is running or not after around 10 cycles any ideas on how I can stop it ?? The clutch seems to work fine cheers for any ideas Quote Link to comment Share on other sites More sharing options...
Motooutcastxxx Posted March 8, 2012 Report Share Posted March 8, 2012 There should be a bracket that basically mounts over it to make sure it stays in place. Check out the walk-through, there's a perfect close up shot towards the end. http://bansheehq.com/forums/index.php?showtopic=140912 You can find one here. http://www.farmandsandtoys.com/partdetail.asp?partid=206 Quote Link to comment Share on other sites More sharing options...
No-lines Posted March 10, 2012 Author Report Share Posted March 10, 2012 Thanks for the reply.That part is missing!!! Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted March 10, 2012 Report Share Posted March 10, 2012 Thanks for the reply.That part is missing!!! If you never touched the motor and that part is missing,I would want to take a peek inside to see if there is anything else that may have been over looked. Quote Link to comment Share on other sites More sharing options...
