erickson483 Posted March 7, 2012 Report Share Posted March 7, 2012 Does anyone have any experience using billet case savers to help protect your case from chain whack? Quote Link to comment Share on other sites More sharing options...
Infamous039 Posted March 7, 2012 Report Share Posted March 7, 2012 Dont use the billet one they break and torch the cases. Get the TM Design Case Saver, best one out there if you ask me. Quote Link to comment Share on other sites More sharing options...
shanYE west Posted March 7, 2012 Report Share Posted March 7, 2012 TM's are nice.. There is some other ones out there that are good too.. but.. stay away from the billet. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted March 7, 2012 Report Share Posted March 7, 2012 Billet case savers transfer energy. You want a case saver that absorbs it. Go with one of the plastic ones. Quote Link to comment Share on other sites More sharing options...
bansheeboy44 Posted March 8, 2012 Report Share Posted March 8, 2012 Billet case savers transfer energy. You want a case saver that absorbs it. Go with one of the plastic ones. Can you run one with a 15 tooth front? Also, do you remove the plastic thing held by 3 little screws when you install it or does the saver go over it? Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted March 9, 2012 Report Share Posted March 9, 2012 Can you run one with a 15 tooth front? Also, do you remove the plastic thing held by 3 little screws when you install it or does the saver go over it? I put my TM Design Works case saver on top of a metal Cascade shift drum cover. Quote Link to comment Share on other sites More sharing options...
bigboybanshee Posted March 9, 2012 Report Share Posted March 9, 2012 15 tooth is no problem. You might have to shave the case saver a little to accomodate it, but you won't have to remove much, if any material to fit a 15T sprocket. All the case savers I have seen go over the neutral switch cover. I also suggest staying away from billet, go with plastic or a "soft" material. Tyler is correct, you want it to absorb the impact, not transfer the energy. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted March 10, 2012 Report Share Posted March 10, 2012 On a plastic one I would just let the chain to the shaving and wearing. That way it is custom fit. Quote Link to comment Share on other sites More sharing options...
jonpeter0420 Posted March 28, 2012 Report Share Posted March 28, 2012 Does anyone have any experience using billet case savers to help protect your case from chain whack? I threw my chain, luckily had a case saver. It still cracked the case but it didn't crack all the way through, I was able to ride back to the truck. I think they're worth the 25 bucks. Quote Link to comment Share on other sites More sharing options...
jonpeter0420 Posted March 29, 2012 Report Share Posted March 29, 2012 I put my TM Design Works case saver on top of a metal Cascade shift drum cover. This design looks legit, however a billet case saver did in fact save my case Quote Link to comment Share on other sites More sharing options...
Nightmare Posted March 29, 2012 Report Share Posted March 29, 2012 in this situation billlet is useless Quote Link to comment Share on other sites More sharing options...
