Antifreeze with oil?
Hey guys i need help...my shee was recently rebuilt and when i put the engine the bike ran great and i noticed a clicking sound coming from the crank case and today i did a oil change and antifreeze came out along with oil...what could cause this??? And can that do anithing with the clicking noise?? Any help is verry appreciated
There is a pipe that connects your water pump to the hose that goes up between the carbs. There is an o ring on that pipe between the cases.
But if that o ring is bad can antifreeze get to the oil? I thought they were separate cuz its transmission oil
The oil in the tranny is common with the clutch, you fill the tranny by putting it in through the clutch cover. With the clutch cover off look at your cases along the bottom either behind or beside the clutch basket, those holes let the oil transfer between the clutch area and the tranny. Also, when you check the tranny oil, the dipstick actually goes into the clutch area. Your leak has to be either the O ring or water pump seal as either will let it leak into the clutch area.
