ticktock Posted March 6, 2012 Report Share Posted March 6, 2012 None really that I can think of, swap out the cdi and give that a try. I really cant think of too much else. Switched out known good coil - same problem. The carbs were cleaned and put together properly? Different parts in each carb! Choke tube on, both have fuel? Running out of options, leading to the cdi\stator adam Quote Link to comment Share on other sites More sharing options...
streetplatoon Posted March 6, 2012 Author Report Share Posted March 6, 2012 None really that I can think of, swap out the cdi and give that a try. I really cant think of too much else. Switched out known good coil - same problem. The carbs were cleaned and put together properly? Different parts in each carb! Choke tube on, both have fuel? Running out of options, leading to the cdi\stator adam yup, carbs are good. I even put my hand over both carbs mouth, both of them are sucking air. I pull the choke out and the engine wants shut down .... what else can it be but the cdi I'll try that tomorrow And post the result. Thanks Adam! Quote Link to comment Share on other sites More sharing options...
EvilBanshee Posted March 6, 2012 Report Share Posted March 6, 2012 I had this problem, I bought my Carbs used. AS a set. Turned out, my needles were different sizes. One side ran leaner then the other. Quote Link to comment Share on other sites More sharing options...
Dunes98 Posted March 6, 2012 Report Share Posted March 6, 2012 (edited) I am no pro but if you are getting a shock from that plug wire i'd say you are getting spark.. Not sure how it would be a cdi issue?? put another plug in it and see if its sparking. Also, would the reason it dies when you pull one plug wire off is because your only firing on one cylinder?? Thats why it doesnt die when you pull the other one. Just thinknig outloud. Edited March 6, 2012 by Dunes98 Quote Link to comment Share on other sites More sharing options...
streetplatoon Posted March 7, 2012 Author Report Share Posted March 7, 2012 I had this problem, I bought my Carbs used. AS a set. Turned out, my needles were different sizes. One side ran leaner then the other. I also bought my carbs used on ebay I'll check that out... Quote Link to comment Share on other sites More sharing options...
streetplatoon Posted March 7, 2012 Author Report Share Posted March 7, 2012 it turned out to be the colder side plug boot, it had a weak spark so I decided to replaced both.... now its on Glamis bro! 1 Quote Link to comment Share on other sites More sharing options...
Jorge_pg Posted September 15, 2015 Report Share Posted September 15, 2015 it turned out to be the colder side plug boot, it had a weak spark so I decided to replaced both.... now its on Glamis bro! What was wrong with it? Mine has been doing the same issue you had? Thanks Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted September 15, 2015 Report Share Posted September 15, 2015 What was wrong with it? Mine has been doing the same issue you had? ThanksThis thread is old. And did you not read what you just quoted? Quote Link to comment Share on other sites More sharing options...
mike0chek Posted September 15, 2015 Report Share Posted September 15, 2015 lmao Quote Link to comment Share on other sites More sharing options...
ECshee Posted October 6, 2015 Report Share Posted October 6, 2015 this stuff is pure gold. Quote Link to comment Share on other sites More sharing options...
