streetplatoon Posted March 6, 2012 Report Share Posted March 6, 2012 what up fellas! I need some help here. My left side pipe is hotter than the right at idle by the way its a new build ... compresion is good stock carbs are synced floats are set ... I'm starting to think my left piston rings arent set causing it to heat up I'm also hearing pinging coming from the hotter pipe but when I hold on to it it stops so I'm thinking its rubbing on something any suggestions ??? Thanks in advance! Quote Link to comment Share on other sites More sharing options...
Surfrjag Posted March 6, 2012 Report Share Posted March 6, 2012 double check everything. swap plug wires, check plugs. if its not getting warm its not fireing... even clean the carb again. Quote Link to comment Share on other sites More sharing options...
streetplatoon Posted March 6, 2012 Author Report Share Posted March 6, 2012 double check everything. swap plug wires, check plugs. if its not getting warm its not fireing... even clean the carb again. oh yeah I also swaped the plug wires same pipe was still getting hotter, I also cleaned the carbs and shot compressed air through them Thanks bro... you guys have any other suggestions ? Quote Link to comment Share on other sites More sharing options...
NetBSD Posted March 6, 2012 Report Share Posted March 6, 2012 leakdown test......... is the plug wet on the cold side? Quote Link to comment Share on other sites More sharing options...
streetplatoon Posted March 6, 2012 Author Report Share Posted March 6, 2012 leakdown test......... is the plug wet on the cold side? I did a leak down test it went well, I just checked the plug on the cold side and it is wet ... What do you think ? Quote Link to comment Share on other sites More sharing options...
Surfrjag Posted March 6, 2012 Report Share Posted March 6, 2012 new plugs and try again. can you tell one side is firing and not the other? Quote Link to comment Share on other sites More sharing options...
streetplatoon Posted March 6, 2012 Author Report Share Posted March 6, 2012 new plugs and try again. can you tell one side is firing and not the other? both side are firing its just that the left side gets alot hotter quick... I'll try some new plugs... Quote Link to comment Share on other sites More sharing options...
NetBSD Posted March 6, 2012 Report Share Posted March 6, 2012 both side are firing its just that the left side gets alot hotter quick... I'll try some new plugs... if the plugs wet i would say spark issue, and since you already swapped wires im gunna say a new plug should do it. im far from an expert tho so dont rape me if im wrong Quote Link to comment Share on other sites More sharing options...
streetplatoon Posted March 6, 2012 Author Report Share Posted March 6, 2012 if the plugs wet i would say spark issue, and since you already swapped wires im gunna say a new plug should do it. im far from an expert tho so dont rape me if im wrong No prob brutha! I'm in the same boat.... I just removed the plug wire on the hotter side while in idle and it turned off ...tried the same thing on the colder side while in idle , it shocked me !!! and the engine kept running I'am about to try some new plugs see what it does be back in a few! Quote Link to comment Share on other sites More sharing options...
streetplatoon Posted March 6, 2012 Author Report Share Posted March 6, 2012 just switched the plug on the colder side no difference did the same thing as above I removed the plug wire it shocked me and the engine kept running... I removed the hotter side plug wire and it shut off (no shock) you think it might be the ignition coil ? Quote Link to comment Share on other sites More sharing options...
ticktock Posted March 6, 2012 Report Share Posted March 6, 2012 Street is your TORS system completely unplugged? Are the pick-up magnets on the outside of the flywheel clean? Is your pick-up gap set to around .020? Check out the TORS and flywheel pickup. If the flywheel is rusty might want to clean it up and try there. Quote Link to comment Share on other sites More sharing options...
streetplatoon Posted March 6, 2012 Author Report Share Posted March 6, 2012 just switched the plug on the colder side no difference did the same thing as above I removed the plug wire it shocked me and the engine kept running... I removed the hotter side plug wire and it shut off (no shock) you think it might be the ignition coil ? just tried the ignition coil from my other banshee.... same symptoms Quote Link to comment Share on other sites More sharing options...
streetplatoon Posted March 6, 2012 Author Report Share Posted March 6, 2012 Street is your TORS system completely unplugged? Are the pick-up magnets on the outside of the flywheel clean? Is your pick-up gap set to around .020? Check out the TORS and flywheel pickup. If the flywheel is rusty might want to clean it up and try all junk wires went to the dump with the tors . just checked the pick up gap and its good flywheel is rust free.... Quote Link to comment Share on other sites More sharing options...
ticktock Posted March 6, 2012 Report Share Posted March 6, 2012 Swap out the CDI, leave your coil on, then do the stator with your CDI and try to narrow the problem if you have access to another set of electrical. Adam Quote Link to comment Share on other sites More sharing options...
streetplatoon Posted March 6, 2012 Author Report Share Posted March 6, 2012 (edited) Swap out the CDI, leave your coil on, then do the stator with your CDI and try to narrow the problem if you have access to another set of electrical. Adam Adam, I didnt want to hear that but was one of my next steps in the process of elimination ... I have all the wires soldered to the stator... any other suggestions before I do that Thanks! Edited March 6, 2012 by streetplatoon Quote Link to comment Share on other sites More sharing options...
