Go ahead and start over....This time give us all the info you have about your bike, the area you ride and anything else you can think of, so that you'll be able
To get some answers for the issues your having ;)
lol ok ill give it a try 350 stock bore agressive port pro designe with adapter no lid tommey t5 stock carbs ride in canada its winter so running 340 mains 30 pilot needle middle clip riding in -10 to +4 celsius hope it helps a bit let me know if i forgette something
You put the Toomey needles in and it runs lean now?? Ok put the old needles back in... :)
How was your bike running with the stock needles? If your in the middle now, you can lower the clip all the way to the bottom, which would raise the needle all the way up...You say you ride WOT? well then the main would play a bigger role than the needle...I ran 340 mains in my stock carbs in 70* weather, so in freezing temps running at WOT, You might want to be at least 350+ on the mains..
