DaweOne Posted March 5, 2012 Report Posted March 5, 2012 tried there needles and my bike kep leaning out ... why so ? Quote
Titan up Posted March 5, 2012 Report Posted March 5, 2012 Go ahead and start over....This time give us all the info you have about your bike, the area you ride and anything else you can think of, so that you'll be able To get some answers for the issues your having Quote
DaweOne Posted March 5, 2012 Author Report Posted March 5, 2012 lol ok ill give it a try 350 stock bore agressive port pro designe with adapter no lid tommey t5 stock carbs ride in canada its winter so running 340 mains 30 pilot needle middle clip riding in -10 to +4 celsius hope it helps a bit let me know if i forgette something Quote
DaweOne Posted March 5, 2012 Author Report Posted March 5, 2012 im runing the bike pretty much wot on the ice on every single gear and a bit right befor the power band to get that light feeling : ) Quote
Titan up Posted March 6, 2012 Report Posted March 6, 2012 You put the Toomey needles in and it runs lean now?? Ok put the old needles back in... How was your bike running with the stock needles? If your in the middle now, you can lower the clip all the way to the bottom, which would raise the needle all the way up...You say you ride WOT? well then the main would play a bigger role than the needle...I ran 340 mains in my stock carbs in 70* weather, so in freezing temps running at WOT, You might want to be at least 350+ on the mains.. Quote
DaweOne Posted March 6, 2012 Author Report Posted March 6, 2012 at 340 needle in tha middle its dark brown on the plugs Quote
