Banshee Problem
Ok so I bought the banshee as a project without exhausts and carburetors.... I recently put those on and it starts right up and has plenty of compression and idles pretty well but when I give it throttle it doesnt sound right and doesnt go in high rpms... The left carburetor with the choke leaks from the overflow and i cleaned them up and still does for some reason.. I dont know if it has something to do with carbs because also on that side the left cylinder didnt seem to be running at one point but then i switched the spark plugs and both worked ok but the throttle was still not good. I jetted the carbs to what the previous owner had that I bought the fmfs from so its not that.. I will post a video tomorrow some time of it running so that you all can better see what I mean and maybe help me out. Any help would be greatly appreciated. Thanks!
is the parking brake hooked up? sounds like the tors system wont let it rev out.
We need a little more info:
What type and size of carbs including current jetting
What exhaust
What is the bore/stroke? Stock
Have you checked the pickup gap on the flywheel .020 is good. Are the carbs sync'd?
Let us know,
Adam
What exhaust
Let us know,
Adam
carbs are stock 26mm, just jetted to 310 mains and 27.5 pilots.
exhaust is fmf gold series
the previous owner said they may have been bored over .50 but i cannot be sure...
yes the carbs are synced
I have tors on them but are not plugged in. And how do I check if its the parking brake sensor.?
Again, I will make a video tomorrow so everyone can see and hear how its running.
had the same problem with mine... leaked all over my new driveway... the needle isn't seating properly, mine was stuck.. what i had to do was take the carb apart, pull the pin out that holds the float and apply a light coat of two stroke oil to the pin and put back together..... worked like a charm
Ill give thata try thanks! and was it just leaking or not reving out as well?
Edited by bball23
All you have to do is unplug the small box under the gas tank on the left hand. It's actually in front of the tank but you can't miss it. Located just opposite of the coil.
I disconnected all of the tors plugs and removed the extra wires
Adam
Also.....have you connected the choke tube between the carbs? What is your elevation and what temp is it near you? Cold be running it really fat and fouling plugs...
Yes I have connected the choke tube. My elevations is 150 feet and today it is 40 degrees Fahrenheit
Hey i made a video:
I made 3 soyou can hear it well so if you want to look at the other 2 just click them. Thanks and let me know what you think it is.. I tried unplugging the tors and it didnt work and the parking brake wire is cut so its not that either.. Also after i jetted it and reinstalled the carbs it wont idle. i adjusted the fly wheel as well and it didnt make a difference. Any other suggestions?
Edited by bball23
