jbooker82 Posted March 5, 2012 Report Share Posted March 5, 2012 I will just stick with my $435 4mill Hot Rods crank from Jeff at FAST. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted March 5, 2012 Report Share Posted March 5, 2012 My billet 18mm CW crank broke in half after 10 months of use, which really wasn't much considering what I do with it. And I just pulled my brother's flywheel off the same crank after two years and I didn't think it was going to come off. If I could get a forged 18mm crank I would run it. I am running a forged crank in my 10DM. Quote Link to comment Share on other sites More sharing options...
421alkybanshee Posted March 9, 2012 Author Report Share Posted March 9, 2012 My billet 18mm CW crank broke in half after 10 months of use, which really wasn't much considering what I do with it. And I just pulled my brother's flywheel off the same crank after two years and I didn't think it was going to come off. If I could get a forged 18mm crank I would run it. I am running a forged crank in my 10DM. I just found out that this crank I purchased is NOT a denny wang crank, It is a crank from crank works. My builder says he and I should be comfortable with it, he has had no issues with their cranks. Quote Link to comment Share on other sites More sharing options...
dirtydownunder Posted March 9, 2012 Report Share Posted March 9, 2012 yeh, i dunno about these cranks. i got one, had to mod the cases to fit ( was only a 4mm) got it from a sponsor too. i dont trust these cranks, and the people that sell em, im a bit weary about now. i think people sell anything these days. Quote Link to comment Share on other sites More sharing options...
camatv Posted March 9, 2012 Report Share Posted March 9, 2012 in my opinion they should all cost the same i mean if the webbs are built by the same homeless chinese peeople there is not any differnce in manufacturing just moving the pin location/. thats what i think is bs about those. the 350cc cranks are 299. i can understand if they have better higher dolla bearings on them. but the extra for the stroke is retarded Quote Link to comment Share on other sites More sharing options...
camatv Posted March 9, 2012 Report Share Posted March 9, 2012 tell the guy you got it from bullshit its a wang crank. crankworks DOSENT paint ther webbs black and use crap TZ bearings. and crap rods. if crankworks sent it to them its from wang.. and everyone is making a buck here and there. i know what i get the SS cranks for straight from wang and its cheaper than the ebay listings most of the time. your being fed a line of bullshit. only true crankworks cranks i have EVER had were hotrod castings or special forged ( from i dont know) and ALL had hot rods rods on them and use NTN bearings.. i also agree id take a hotrods 4 mill crank from jeffro for the extra 20 bucks. Quote Link to comment Share on other sites More sharing options...
camatv Posted March 9, 2012 Report Share Posted March 9, 2012 i mean your crank dosent look JUST like this?? except its a 4 mill http://www.ebay.com/itm/BANSHEE-YFZ350-PIN-WELDED-NEW-CRANKSHAFT-STD-OEM-SIZE-/250846982759?pt=Motors_ATV_Parts_Accessories&hash=item3a67a53267&vxp=mtr#ht_849wt_1163 better pic of the rods http://www.ebay.com/itm/NEW-BANSHEE-YFZ350-2-SET-CONNECTING-ROD-SET-115mm-/250783531903?pt=Motors_ATV_Parts_Accessories&hash=item3a63dd037f#ht_500wt_1180 it MAY have been assembled by crankworks i dont know. im not sure why they would not use hotrods webbs tho. Quote Link to comment Share on other sites More sharing options...
stroking Posted March 9, 2012 Report Share Posted March 9, 2012 agreed...ALL hotrod cranks that i have installed had gray webs and rod with either blue or red o-rings on the bearing all those black web cranks are the same....and i can prove it...just dont want to call out some of the companys. that one the guy paid $850 is identical to the $395 TDR CRANK and for $850 he got to make 10 passes on it before the weld broke and web cracked and when i called the guy he wanted to charge me $350 to fix i,so i sent it to another builder to look at and he said to him it looked to be a defect in the material and it cost around $330 to fix so owner just decided to buy a new TDR crank. i think after a while TDR will be to number 1 Crank seller once more people realize there spending more elsewhere for the same type of crank only diference you will find is some builders weld the cranks better and some comes with a TZ BEARING which is something i would not run anymore so ! Quote Link to comment Share on other sites More sharing options...
Worstenemy453 Posted March 10, 2012 Report Share Posted March 10, 2012 Are the black ones bad ? I just bought a black one like that i guess but my rods dont look like that. Was told it was a Vito's. Trued and welded. Quote Link to comment Share on other sites More sharing options...
stroking Posted March 10, 2012 Report Share Posted March 10, 2012 Are the black ones bad ? I just bought a black one like that i guess but my rods dont look like that. Was told it was a Vito's. Trued and welded. just add alittle more weld to the pin and your good !!! Quote Link to comment Share on other sites More sharing options...
#1JUANstunna Posted March 10, 2012 Report Share Posted March 10, 2012 That may be a wang crank with black lobes. How much did you pay and was it used? HAHA you said WANG CRANK! Someone had to make the joke. Quote Link to comment Share on other sites More sharing options...
Worstenemy453 Posted March 10, 2012 Report Share Posted March 10, 2012 just add alittle more weld to the pin and your good !!! I can do that, whats the best bearings for them ? Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted March 10, 2012 Report Share Posted March 10, 2012 Are the black ones bad ? I just bought a black one like that i guess but my rods dont look like that. Was told it was a Vito's. Trued and welded. My vitos has there name laser etched on the rods along with the size. Mine says vitos 110. Quote Link to comment Share on other sites More sharing options...
Worstenemy453 Posted March 10, 2012 Report Share Posted March 10, 2012 My vitos has there name laser etched on the rods along with the size. Mine says vitos 110. Ah, Just looked, it says Vitos on one side of each rod and SC 115 on the other sides. Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted March 10, 2012 Report Share Posted March 10, 2012 Then you got a real vitos crank. I've heard bad things but yet to have any personally with the crank. Quote Link to comment Share on other sites More sharing options...
