Plugs to run?
don't know if it makes a difference or not but I was told to run BR8EG in my shee... just a racing version I guess. Was told they won't foul as quickly. If there's any truth to that, we'll see... at any rate, never hurts to have some extra plugs on hand!
eg plugs are great but are discontinued.
try a br8eix plug the cdi ignition will have a better time firing that plug at higher RPM's
that would be why i can never find them. i used to run them all the time and usually got a season or better out of them.
no reason at all to run a br9 plug. It will be more prone to fouling as it is a heat range colder.
now if you had a real hot setup that liked to rattle when you hot lapped it, then try one out.
