Transmission seal question
Just got a seal that goes behind the front sprocket and was wondering if this is a hard thing to change.
pull the sprocket and the sleeve behind it that the seal rides on. pop seal out. reassemble in reverse order.
  • 1 year later...
Hey guys is this the part needed to change when you have a transmission leak on the right lower side of the bike?
No, the sprocket is on the left side of the motor. If you have a leak on the right side, it's either the clutch cover gasket or cracked cases.
Clean it well, run it a bit and look for where it's coming from.
I rode it today and it looks like its leaking from the right lower side through the gasket and from the water pump on the clutch cover but it only leaks alot when riding/hot... You think a new gasket will fix the leak or its not that simple?? And what cases are were you talking about?
