dcalsv02 Posted March 2, 2012 Report Share Posted March 2, 2012 I plan on doing a new motor after this riding season. I have a list put together and was hoping you guys could give me ideas, info, or ideas for added parts i may have forgotten. +4 long rod crank Tz and Maxload bearings Porting on virgin stock cyls. Port match cases Custom cut domes extra pwk 35 (currently running 2-1 setup) New tranny modded by cam Piston kit Piston windowed All necessary gaskets. Stiffer Springs? I already have the modded star and shift shaft, billet basket, new clutch, billet impellar. Quote Link to comment Share on other sites More sharing options...
dcalsv02 Posted March 2, 2012 Author Report Share Posted March 2, 2012 I have it narrowed down to cam at redline or kevin at herr jugs. Im leaning towards redline because its only a couple hours away, but I like having different setups than everyone else around my area, so i might have kevin do it to have something different. When i get ready to shell out the dough, ill give them both a call. Ill be assembling the motor myself, just need all the parts, porting, and machining done. Quote Link to comment Share on other sites More sharing options...
Infamous039 Posted March 2, 2012 Report Share Posted March 2, 2012 Nice build sheet you have there. Bike should run hard man. Quote Link to comment Share on other sites More sharing options...
dcalsv02 Posted March 2, 2012 Author Report Share Posted March 2, 2012 I hope so. Im shooting for about 80. Not sure if that setup will require race or pump. I know it will depend on my domes, but Id like a solid 80. Quote Link to comment Share on other sites More sharing options...
dcalsv02 Posted March 2, 2012 Author Report Share Posted March 2, 2012 I already have the pancake bearing, adjustable timing plate, vforce, and good exhaust. good looking out though zilla. I was tossing around clutch ideas in my head. not sure if i wanted to do the stiffer springs to keep the stock cover and stock look going, or go ahead and do the lockup. I have a ninja that knows direct drive pretty well and may be able to get me a good deal on a lock up setup. I may go that route. Quote Link to comment Share on other sites More sharing options...
SandmanPNW Posted March 2, 2012 Report Share Posted March 2, 2012 I already have the pancake bearing, adjustable timing plate, vforce, and good exhaust. good looking out though zilla. I was tossing around clutch ideas in my head. not sure if i wanted to do the stiffer springs to keep the stock cover and stock look going, or go ahead and do the lockup. I have a ninja that knows direct drive pretty well and may be able to get me a good deal on a lock up setup. I may go that route. Where did you get a ninja? Been looking for years bro Quote Link to comment Share on other sites More sharing options...
dcalsv02 Posted March 2, 2012 Author Report Share Posted March 2, 2012 Where did you get a ninja? Been looking for years bro You know I cant tell you that Sandman. The ninja will have my ass. Quote Link to comment Share on other sites More sharing options...
421alkybanshee Posted March 3, 2012 Report Share Posted March 3, 2012 Your list sounds just like I have just done today. I just got Dan at A&S to deliver my stock cyl's that he drag ported and case ported to match , 4 mil trued and welded crank, noss head with cut domesw for alky, and he suggested a set of 39mm keihin carbs with fuel pump, so I got those also from him. Your setup and mine sound close except for me(alky) you (gas). Im gonna run the v force and cpi inframes also. I think we will have some hard running machines. I dont know as if I have anymore ideas for you ,but if you come up with anything else please let me know. Quote Link to comment Share on other sites More sharing options...
jayzx10r Posted March 3, 2012 Report Share Posted March 3, 2012 Are you running straight cut primary gears? If not, stay away from the TZ bearing!! Quote Link to comment Share on other sites More sharing options...
421alkybanshee Posted March 3, 2012 Report Share Posted March 3, 2012 Are you running straight cut primary gears? If not, stay away from the TZ bearing!! Im planning on running primarys, Not sure about dcalso2? Why? will the load kill that brg? Quote Link to comment Share on other sites More sharing options...
dcalsv02 Posted March 3, 2012 Author Report Share Posted March 3, 2012 I wasn't planning on running straight cut gears. Why stay away from the tz? Quote Link to comment Share on other sites More sharing options...
Titan up Posted March 4, 2012 Report Share Posted March 4, 2012 I was tossing around clutch ideas in my head. not sure if i wanted to do the stiffer springs to keep the stock cover and stock look going, or go ahead and do the lockup. I have a ninja that knows direct drive pretty well and may be able to get me a good deal on a lock up setup. I may go that route. You can run the slingshot lockup under the stock cover, just grind the 3 nubs off on the inside for clearance..Might be able to get get away with all stock springs, if not 3 stock 3 hd would work for sure. Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted March 4, 2012 Report Share Posted March 4, 2012 I wasn't planning on running straight cut gears. Why stay away from the tz? Because the TZ bearing will not handle the side loads that helical gears put on it. They will handle far greater radial loads than any other Banshee crank bearing though! Quote Link to comment Share on other sites More sharing options...
dcalsv02 Posted March 4, 2012 Author Report Share Posted March 4, 2012 Because the TZ bearing will not handle the side loads that helical gears put on it. They will handle far greater radial loads than any other Banshee crank bearing though! What bearing should I use then? Quote Link to comment Share on other sites More sharing options...
ticktock Posted March 4, 2012 Report Share Posted March 4, 2012 What bearing should I use then? Maxloads Quote Link to comment Share on other sites More sharing options...
