Larry's Shee Posted March 12, 2012 Report Share Posted March 12, 2012 I would consider getting a matched set of cases and take that out of the mix. Quote Link to comment Share on other sites More sharing options...
252wheelieking Posted March 12, 2012 Author Report Share Posted March 12, 2012 I cleaned the cases & they are matching cases. both cases have X9 142 on the upper & lower cases. I am leaning more towards something is out of spec. with the cases. I'm going to buy another set of cases & rebuild it again except im going 4mil cub this time. Quote Link to comment Share on other sites More sharing options...
rodneym Posted March 12, 2012 Report Share Posted March 12, 2012 cool man keep us posted. u gonna build it all yourself? Quote Link to comment Share on other sites More sharing options...
252wheelieking Posted March 12, 2012 Author Report Share Posted March 12, 2012 cool man keep us posted. u gonna build it all yourself? I will....yes, it's easy.... I built my complete bike from the frame up. Quote Link to comment Share on other sites More sharing options...
dmrhottie Posted March 13, 2012 Report Share Posted March 13, 2012 hmm, i was just curious if you let cameron sawyer "dyno tune it" ???? word on the streets that usualy helps Quote Link to comment Share on other sites More sharing options...
252wheelieking Posted March 13, 2012 Author Report Share Posted March 13, 2012 hmm, i was just curious if you let cameron sawyer "dyno tune it" ???? word on the streets that usualy helps I dont know a cameron sawyer....not fully understanding what you mean....Are you saying i should let him dyno tune it or did i let him dyno tune it? Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted March 13, 2012 Report Share Posted March 13, 2012 where abouts are the markings you mentioned? Quote Link to comment Share on other sites More sharing options...
sprinklerman Posted March 13, 2012 Report Share Posted March 13, 2012 where abouts are the markings you mentioned? Mine are scribed on the back of the case by the rear mount. Quote Link to comment Share on other sites More sharing options...
252wheelieking Posted March 13, 2012 Author Report Share Posted March 13, 2012 where abouts are the markings you mentioned? Mines are on the backside of the cases near the #15 bolt on the upper case. Right below that on the lower case are the same markings . Looks like someone ingrave them by hand with a tool or something. Quote Link to comment Share on other sites More sharing options...
252wheelieking Posted April 13, 2012 Author Report Share Posted April 13, 2012 found the problem to all this madness....incorrect float height on the right carb causing the carb to run float bowl dry at WOT.... Quote Link to comment Share on other sites More sharing options...
lms1977 Posted April 14, 2012 Report Share Posted April 14, 2012 found the problem to all this madness....incorrect float height on the right carb causing the carb to run float bowl dry at WOT.... wow that sucks.!!! but atleast you found it good luck on the cub Quote Link to comment Share on other sites More sharing options...
ticktock Posted April 14, 2012 Report Share Posted April 14, 2012 found the problem to all this madness....incorrect float height on the right carb causing the carb to run float bowl dry at WOT.... No way man. Your talking about cooking two engines because of float height? You run pinned for long periods of time? Quote Link to comment Share on other sites More sharing options...
252wheelieking Posted April 14, 2012 Author Report Share Posted April 14, 2012 wow that sucks.!!! but atleast you found it good luck on the cub Thanks....I hope it goes well. Quote Link to comment Share on other sites More sharing options...
252wheelieking Posted April 14, 2012 Author Report Share Posted April 14, 2012 I have a set of grand river racing ported cylinders for sale. Let me know. im straight..... I have a 421 cub now Quote Link to comment Share on other sites More sharing options...
252wheelieking Posted April 14, 2012 Author Report Share Posted April 14, 2012 No way man. Your talking about cooking two engines because of float height? You run pinned for long periods of time? yes I cooked two engines because of float height & the 1 psi. loss in 6mins. That was acceptable & still a small air leak... Yes I run my shee WOT throttle until it's almost maxed out then I back off to 3/4 throttle. I ride back roads, alot of long straights & wide open fields cause I live in the country. I sat down & thought about everything i did & didnt do. Then it clicked that last year when I was at busco my right carb was leaking fuel from the over flow drain tube. So I adjusted the right float by eye so it would stop leaking. I pushed the float tab up to much & it restricted the carb from getting the proper amount of fuel. So as long as i ride around about half throttle it would be fine, but at WOT & hard accleration the engine would run the right carb dry. Reason is because the float level was incorrect & not allowing the right float bowl to full properly. ANOTHER LESSON LEARNED Quote Link to comment Share on other sites More sharing options...
