coolant question
Chip M
I bought a 96 Banshee a few weeks ago, it stuck in 2nd gear. I wanted to try a rebuild in the garage. New pistons, rings and all new upper and lower seals along with some shifter parts and a outer tranny bearing.(Along with MUCH help from you great bunch of guys) I got it finished last night and was pumped to give it a try after work today. I pretty much just stuck the engine back in the frame and bolted on the pipes. I fired it up and let it idle for a couple of minutes, like I was told to in here and then I wanted to make sure I could get through 2nd gear since that was my original problem, before putting it all back together. Once in second I figured I might as well try a couple more gears, so I grabbed 3rd and 4th gear like I had just stole it. WOW!! Really hard for me to believe how much pull these things have. Mine is pretty much stock compared to some I read about, only a little O.S. bore ,FMF pipes, ProDesign CoolHead and VForce Reed Valves. Carbs I do not know about yet. Now to tell you the dumbass thing I did. I ran without any coolant in the motor. I only did the idle to let it warm up and two 50 yard screams down my street but I do not know how much the banshee's can take without coolant. Will it melt the impeller that quick?. Is it likely that I did any permanent damage from the heat? Nobody can beat me down as much as I sit here beatin myself down so please let me know honestly how bad I screwed up. Thanks again for all you guys that have helped me in my posts during my rebuild and all the great tips that I have read in others posts.
I live in Florida, It is about 75-80 degrees outside. How would I tell if it overheated? I saw a very little smoke coming from the pipes right where they come out of the engine, but it stopped about a minute of two after I shut down. I was just in way too much of a hurry to see if the bike would run.
Got it. Thanks much guys. That sick feeling in my stomach is starting to settle down. I will post the pics when I get it all back together so you can see what you and I did... lol. It is really not much to look at, I mean just not all the chrome and sweet colors i see on some of the pics posted, But the bike did not have a bunch of stripped out bolts and bass ackwards engineering l Have seen on some other project bikes. Frame looked straight and the plastics were all in good shape. For 500 bucks I couldn't turn it down. This site really rocks with all the help offered and knowledge shared. I plan on signing up as a paying member and hanging around for a while.
Did you just forget?
Yeah it just totally slipped my mind. I was so pumped about trying it out,not even a seat to sit on, Just motor and pipes. lol. Bought the coolant today, I will pop off the cover and check for any damage. Hoping for the best.
Shit happens man. Since there is no coolant just rip the topend off
