BLOODRAGE Posted February 26, 2012 Report Share Posted February 26, 2012 just wondering if it was possible to get some vids posted.the straight cut gears i have sound terrible Quote Link to comment Share on other sites More sharing options...
gotta_goatsfast Posted February 26, 2012 Report Share Posted February 26, 2012 Sound terrible how? Mine have a slight "whine" or "howl" from off idle to about 4000rpm but nothing that turns heads. The exhaust and intake usually overpower said whine anyway. Quote Link to comment Share on other sites More sharing options...
BLOODRAGE Posted February 26, 2012 Author Report Share Posted February 26, 2012 mine sounds more like they are grinding.here have a listen you can really notice it at the end Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted February 26, 2012 Report Share Posted February 26, 2012 Check your cushions for excessive wear if your basket uses them. Are you sure your crank bearings are all in good shape? Check the idler gear for play on the trans shaft, it will growl a little bit when it starts to get worn out. - Jared Quote Link to comment Share on other sites More sharing options...
BLOODRAGE Posted February 26, 2012 Author Report Share Posted February 26, 2012 the cushions in the clutch basket are new,the crank bearings are also new.i have the maxload and tz bearings.the straight cuts i have are used,i got em off FAST.i guess the last owner had the idler gear rub againts the big gear. if i buy new gears will it be quieter? its to the point where i dont want to be seen running the bike.tons of power just too noisey (embarrasing) Quote Link to comment Share on other sites More sharing options...
NickisGod Posted February 26, 2012 Report Share Posted February 26, 2012 i have them i cant say i have this problem. funny thing is i watched a video before that is kinda like ur problem. at least ur banshee dosnt sound like its going into defcon 5 Quote Link to comment Share on other sites More sharing options...
BLOODRAGE Posted February 27, 2012 Author Report Share Posted February 27, 2012 damn thats loud mine in person sound like theres too much play between the gears.so it makes a grinding noise. im not going to monkey with it till my billet clutch cover comes in,ill post a video of the play in the gears too see what you guys think. Quote Link to comment Share on other sites More sharing options...
Jereme6655 Posted February 27, 2012 Report Share Posted February 27, 2012 As for the banshee.....I don't know the problem... Nick.....good god that car sounds absolutely horrible with those sequential gears......damn.... Quote Link to comment Share on other sites More sharing options...
volvo63' Posted February 27, 2012 Report Share Posted February 27, 2012 I think that that video just blew my headphones. Quote Link to comment Share on other sites More sharing options...
registered user Posted February 27, 2012 Report Share Posted February 27, 2012 hard to tell but i didnt hear any strange noise that would be associated with the gears. but anytime you have gears like that you may experience a whine. vehicle trannsmission and transfer cases do it to some extent and a engine using gear drive timing do it pretty loud. you can hear in this video Quote Link to comment Share on other sites More sharing options...
NickisGod Posted February 27, 2012 Report Share Posted February 27, 2012 I think that that video just blew my headphones. thats what im here for Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted February 27, 2012 Report Share Posted February 27, 2012 Any resason why your running straight cut gears? There are plenty of high hp banshee's running around with the regular heli cut gears. Quote Link to comment Share on other sites More sharing options...
BLOODRAGE Posted February 27, 2012 Author Report Share Posted February 27, 2012 i was told to use straight cut gears plus with my stock motor i took the fly wheel cover off and started the bike i could see the fly wheel move side to side so i figured it would be the better way to go. im really not sure how much hp my motor is putting out or if i even need straight cuts at all,might be over kill.but the last thing i want is the tz bearing to explode Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted February 28, 2012 Report Share Posted February 28, 2012 i was told to use straight cut gears plus with my stock motor i took the fly wheel cover off and started the bike i could see the fly wheel move side to side so i figured it would be the better way to go. im really not sure how much hp my motor is putting out or if i even need straight cuts at all,might be over kill.but the last thing i want is the tz bearing to explode I guess if the exploding tz bearing was a concern I would have went with a Max load bearing with Helicut gears. The guys who swap to straight cut gears are running huge motors, or they need a different gear ratio for 1/8 or 1/4 mile asphalt drag racing. I am running a TZ bearing with helicut gears with no problems. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted February 28, 2012 Report Share Posted February 28, 2012 i was told to use straight cut gears plus with my stock motor i took the fly wheel cover off and started the bike i could see the fly wheel move side to side so i figured it would be the better way to go. im really not sure how much hp my motor is putting out or if i even need straight cuts at all,might be over kill.but the last thing i want is the tz bearing to explode If you can see the flywheel move side to side you have bigger issues. It should not move at all other than in a circle perfectly straight. Can you shoot video of your flywheel? Quote Link to comment Share on other sites More sharing options...
