Is this even possible? I wanted to build a 4 mil but have been thinking about a 10 now. What kind of tranny mods will I need to do? This is a trail bike but will be dragged for fun sometimes.
And has anyone have experience with TDR cranks from bansheedepot
10 mil serval can be bought for about 2400$ maybe less 1200ish top end kit with domes for noss type head 850ish for a good crank, seals 20 and trenching. Pm me for more info. I will discuss who I am going through and why.
Adam
Since its a trail bike, I figured a stock cylinder would be good. (if it's possible). Because I could build it now and later on down towards next summer buy a serval cylinder. I didn't know if a stock cylinder 10 mi is possible because of port timings though
Dont forget you will pretty much need all new clutch componets if yours are even slightly worn. Also a modded tranny (under cut, every other dog removed) is ideal if you intend on shifting fast at high RPM. Ther is a bit more to it then just buying a new topend and crank.
Its not very common because of the work involved. A 10mil crank doesn't fit in stock cylinders very well. If you want to stick with stock cylinders look into a 7mil crank. Still requires case work but it will fit in stock cylinders.
