adamhamy Posted February 23, 2012 Report Share Posted February 23, 2012 My shifter was very loose I took the motor out and split the cases and noticed the bolt for the return spring snaped..other half is in case..whats the fix fir this? Drill it out and tap it? Where can I get another bolt like that but bigger sny help would be great..first time rebuilding..its going great till I rsn into this..thanks! Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted February 23, 2012 Report Share Posted February 23, 2012 You can't get it out with a easy out ? Quote Link to comment Share on other sites More sharing options...
camatv Posted February 23, 2012 Report Share Posted February 23, 2012 if the eccentric is completely broken off. then heat the case up with a small propane torch or a small mapp gas torch it wont take much if you smell locktight coming out het it a few times and let it cool down shouldnt need more than aabout a minute or so for each cycle. if no locktight heat it up for a lil bit probably 2 mins at most. and then drill it out in the center with a smaller drill bit than the bolt's threads most of the time you will break it loose and it will actually screw into the other sided of the case if i rember right. pop right out. Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted February 23, 2012 Report Share Posted February 23, 2012 Ya, you don't want to drill/tap to a larger size. The bolt that goes in there is off center (ecentric) to the threads for adjustment for shifter. Quote Link to comment Share on other sites More sharing options...
adamhamy Posted February 23, 2012 Author Report Share Posted February 23, 2012 Damn you guys kick as%....that was fast.....whats an easy out? The bolt snapped in half......so heat the case and then drill a small Hole in bolt and screw it thru si it comes out the other side? Quote Link to comment Share on other sites More sharing options...
adamhamy Posted February 23, 2012 Author Report Share Posted February 23, 2012 Thanks camatv and everyone! Just joined yesterday..thanks again! Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted February 23, 2012 Report Share Posted February 23, 2012 It's a left handed drill bit and things with left handed threads that bite the screw. You drill a hole in the middle going with the left handed threads and sometimes they will bite and UN screw the bolt. If not you drill the hole and you tap in the easy out with a hammer and you can back out the screw. They come matched with the drill bit and easy out on the kit. But some times its not that easy. Quote Link to comment Share on other sites More sharing options...
camatv Posted February 23, 2012 Report Share Posted February 23, 2012 if the hole dosent go through you can use a lefty. if the hole goes through and you ahve access to the other side i just use a std bit and screw them right out. it works nearly every time. lil heat and wala! but of course you have to have the cases split. if the cases arent split you cna try a lefty bit BUT id split them anyways to get all of it cleaned out for sure.. Quote Link to comment Share on other sites More sharing options...
