drag parts: Trinity drag pipes, OEM crankshaft, VITO's Hemi Head, +6" swingarm
I have some more really nice Banshee parts for sale. Most of these parts are basically still new with about 20 minutes of total use since new!! Please reply with any questions. All parts would be packaged extremely well. I have sold a few cranks, engines, cylinders and etc. on HQ and received great feedback on everything. I also offer your money back if you are not satisfied, after returning the parts in the same condition as recieved. I'm located in Wisconsin Dells, WI.
Most of these parts were bought brand new and only used for 20-30 minutes total!! The bike was never actually driven...the motor was just ran and tuned. These parts are basically still new and work perfect. You would be hard pressed to find used parts this nice.
1)A set of 38mm Lectron carbs w/alky set-up. SOLD
2)Vito's Hemi Head II with 18cc small bore domes. These parts have about 20 minutes of total use since new. Everthing is in perfect shape with no damage or wear. No major scratches or scuffs...overall it looks excellent. One o-ring is missing though. $125 shipped
3)Alloy intakes w/cross-over tube. The intakes were used with 28mm carbs. The parts are very clean and in excellent shape. $80 shipped
4)Swingarm Shop +6 swingarm w/stock carrier. This swinger has no skidplate mounts and is powercoated silver. It was mounted to a bike but never used! It does has some minor chips in a couple tiny areas, overall it looks great. With a little dust/dirt you wouldn't even notice the flaws. The front needle bearings are also brand new. Includes swinger, carrier, adjustment hardware and etc...everything pictured. $150 plus actual shipping.
5)Trinity Racing OOF chrome drag pipes w/stingers. They were used for about 20 minutes but the bike was not driven. These have no dents or damage. There are some very very tiny spots of chrome that is chipped/flawed. You only notice it when looking at it while holding them in your hands...then putting it right up to your face. The area is also on the underside of the bend so it is not seen while on the bike. The pictures don't even show the flaw! Trinity claims these work with 350-535cc engines. The mounting brackets are included but not pictured. You would be hard pressed to find another set of used pipes this nice!! $400 plus actual shipping.
6)Pro Design alloy adjustable timing plate. This was used more than 20 minutes but is in great condition. This has about 200 miles of total use since new. The threads are also perfect. $50 shipped.
7)lightweight/lightend OEM flywheel. $50 shipped
8)Mikuni 34mm D-slide carbs. These are used and in good working condition. They are complete with no damage or major wear. The outside finish is a little dull. $100 shipped
9)OEM Blaster front shocks. These shocks are in mint condition and were barely used. They look and work perfect. They are actually really cool looking shocks for OEM....they look sharp when mounted on a bike. $45 + actual shipping.
10)Regina 520 X-ring 90 link chain. The chain is brand new. A master link is included but not pictured. $65 shipped
11)Moose Racing rear axle bearing+seal kit. The parts are brand new in the package. This is for dual-row carriers with 4 bearings total. It also fits 2006< stock YFZ450 and 2007< Raptors. $50 shipped
12)Denton adjustable steering stabilizer. It is technically made for a YFZ450 but I also used it on a Banshee and it worked fine. It's in good shape with no damage. $65 shipped
13)Pivot Works linkage rebuild kit. The kit was removed from the original package but was never used. It is complete and in new condition. SOLD
14)Dynatek adjustable cdi box. It looks and works like new. The wires, plugs and shrink wrap have no damage or wear. SOLD
15)Vito's aluminum spacers/plates for strokers. Both are brand new in the package. There is one .063 and one 4mm. The .063 includes two base gaskets, the 4mm has no gaskets. $30ea shipped
16)OEM stock crankshaft. The great works excellent with no problems. It only has about 50 hours of total use. Was ran with Klotz oil too. The needle bearings are not included cause they are currently MIA. $140 shipped
17)complete OEM airbox, two K&N airfilters w/Pre-filters and an aluminum adapter. The airbox has a couple small holes burned in it from the pipes. It does not affect the mounting or performance. Otherwise the parts are in excellent condition. Both filters are very nice with no damage or wear. These were back-up filters and was only used 2-3 times each. They are both clean and ready to use. $60 shipped
  • Replies 40
  • Created
  • Last Reply
Top Posters In This Topic
PM sent on the crank. Might also be interested in the chariot or hemi head and the swing arm.
Can the swing arm be used with a stock rear shock ?
This was a rigid set-up so I'm not really sure. You might be able to use a stock shock...it depends on your weight and what your doing with it.
