sheerider11 Posted February 20, 2012 Report Share Posted February 20, 2012 Who can cut my domes for my 4 mil?? Quote Link to comment Share on other sites More sharing options...
ticktock Posted February 20, 2012 Report Share Posted February 20, 2012 It would just be better to buy a set of 4mil domes and then sell your old ones to cover the cost. Is you have Pro Design/NOSS/Chariot heads the Rootracing can get the domes you need. Hope that helps, Adam Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted February 20, 2012 Report Share Posted February 20, 2012 Just call NOSS and have him cut you a set. He will probably need some cylinder specs like base gasket thickness. Quote Link to comment Share on other sites More sharing options...
Coupelx Posted February 20, 2012 Report Share Posted February 20, 2012 It would just be better to buy a set of 4mil domes and then sell your old ones to cover the cost. Is you have Pro Design/NOSS/Chariot heads the Rootracing can get the domes you need. Hope that helps, Adam wut? Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted February 20, 2012 Author Report Share Posted February 20, 2012 I called east coast, they said they need the motor so they can check squish and get it set up perfect. Any one have input on the quality of the work there? Quote Link to comment Share on other sites More sharing options...
dlnoss Posted February 21, 2012 Report Share Posted February 21, 2012 I make custom domes almost every day. The more info you have, the better. Bore, deck height, piston part number, etc. Give me a call if you want at 918-358-3804 -David Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted February 21, 2012 Report Share Posted February 21, 2012 I make custom domes almost every day. The more info you have, the better. Bore, deck height, piston part number, etc. Give me a call if you want at 918-358-3804 -David That's the man to call! Quote Link to comment Share on other sites More sharing options...
camatv Posted February 21, 2012 Report Share Posted February 21, 2012 i'd recomend NOSS as well. give him a call and you can get the measurement that he needs to do the domes for you. nothing like a properly set up dome shape. not sure what happend on our last deal tho? no returns of phone calls or messages? Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted February 21, 2012 Author Report Share Posted February 21, 2012 Alright perfect. Thanks guys. Quote Link to comment Share on other sites More sharing options...
