stop switch assembly
11AGUY
5FK-82530-00-00 STOP SWITCH ASSY
I am putting the clutch back together and put the cover on and have the stop switch assembly hanging down and can't remember how this thing hooks in... it appears as if it hooks onto one of the clutch cover screws... anyone have any pics...
is this thing necessary??? can you unplug this and still get the machine to run??? I see some guys with this part off their banshee's....
any close up pics would be awesome
Here is how most of it goes. The hook on the end hooks to the tab on the inside surface of the brake pedal. There is a small tab with a hook on it that goes under the clutch cover bolt by the kicker to kind of stabilize the crooked rod. It will run without the switch, but it's kind of nice to let your buddy behind you know that you're stopping, so he doesn't ass end you and shove you over the cliff you just barely stopped for. The better way to have a brake switch is with a banjo bolt pressure switch. You can buy them on ebay or from rocky mountain atv.
you the man!!! thanks a bunch.... so that triggers the rear brake light and its the only purpose??? I'll check on that banjo bolt
