stripping paint off plastic
Dunefreak
Whoever painted the plasics on my banshee did a shitty job. Paint is cracking about every where and I don't want to have to dump my fenders. Is there easy way to strip the old paint off so I can have the fenders repainted?
I would get paint stipper and paste it on and let is sit then whipe it off and/or us a pressure washer and repeat as many times as you need. If you are planning on repainting them I would strip them all the way down to the bare plastic. Never wanna trust some else's prep or primer work, especially with the problems you are having. Then when you get them fully stripped you are gonna want to clean them with laquer thinner or bleach water and then fully scuff them for preperation on the next paint job. JMO.. good luck man!
if you are going to repaint it, just use some lacquer thinner. let it soak, then wipe it off. then sand the rest of the stuck on paint. you are going to have to sand the plastic to paint it good.
Unless he uses krylon fusion I did mine and no sanding required just clean them really good dry and spray.
