bent axle
eldreder
ive got a bent durablue axle, i'm not sure how bad it's bent, looks to be about an eigth inch of travel up/down on the end, i'll measure it more precisely tomorow.
durablue said they can straighten them for $80 dollars if it's bent less than 186 thousandths.
Does anyone know how they bend them back and if i could try it myself? i have axcess to a decent machine shop
Put it between centers in a lathe. Find the point with the most runout. That's the middle of the bend. Put it in a hydraulic press. Bend it slightly past straight to allow of it to spring back. Recheck it in the lathe. Hopefully the lathe and the press aren't very far apart. You're gonna make a lot of trips back and forth.
