eldreder Posted February 12, 2012 Report Share Posted February 12, 2012 ive got a bent durablue axle, i'm not sure how bad it's bent, looks to be about an eigth inch of travel up/down on the end, i'll measure it more precisely tomorow. durablue said they can straighten them for $80 dollars if it's bent less than 186 thousandths. Does anyone know how they bend them back and if i could try it myself? i have axcess to a decent machine shop Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted February 12, 2012 Report Share Posted February 12, 2012 If you have access to a decent shop then I'm sure heat and pressure will do the trick. You just need a way to spin it true and have a dial indicator to measure the bend. Quote Link to comment Share on other sites More sharing options...
Coupelx Posted February 12, 2012 Report Share Posted February 12, 2012 i wont pretend to know anything about how axles are made but i dont think i would heat it. any machine shop worth a damn should be able to straighten it though. Quote Link to comment Share on other sites More sharing options...
mookie Posted February 12, 2012 Report Share Posted February 12, 2012 No heat!! Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted February 13, 2012 Report Share Posted February 13, 2012 Well there you go no heat. Why don't you call dura blue and just ask. Don't say you want to do it your self but just ask what the process is. I doubt its some secret there keeping Quote Link to comment Share on other sites More sharing options...
eldreder Posted February 13, 2012 Author Report Share Posted February 13, 2012 that's probably a good idea Quote Link to comment Share on other sites More sharing options...
Starwriter Posted February 13, 2012 Report Share Posted February 13, 2012 Put it between centers in a lathe. Find the point with the most runout. That's the middle of the bend. Put it in a hydraulic press. Bend it slightly past straight to allow of it to spring back. Recheck it in the lathe. Hopefully the lathe and the press aren't very far apart. You're gonna make a lot of trips back and forth. Quote Link to comment Share on other sites More sharing options...
thomas h. Posted February 13, 2012 Report Share Posted February 13, 2012 I used some washers to shim the rim to get by. It was two one one lug and one on another worked perfect. Quote Link to comment Share on other sites More sharing options...
