350 screamer Posted February 12, 2012 Report Share Posted February 12, 2012 sorry sounds sucky, but wats goin on, its sounds like left is cutting out or cud be the air fuel, the i checked the slide it looks a lil bit off still musta came undone.. orrrr Quote Link to comment Share on other sites More sharing options...
Fastassbanshee96 Posted February 12, 2012 Report Share Posted February 12, 2012 Sounds like your out of sync. What's your jetting at. Quote Link to comment Share on other sites More sharing options...
350 screamer Posted February 12, 2012 Author Report Share Posted February 12, 2012 Sounds like your out of sync. What's your jetting at. 280 mains 27.5 pilot its runnin like 99% better then it was Quote Link to comment Share on other sites More sharing options...
350 screamer Posted February 12, 2012 Author Report Share Posted February 12, 2012 (edited) 280 mains 27.5 pilot its runnin like 99% better then it was its cuttin out in low rpms ans sum back fire, but if i hold it at a steady mid range RPM both cylinders are fine, carbs are in sync to i dont get it one bit nned help on this one guys Edited February 12, 2012 by 350 screamer Quote Link to comment Share on other sites More sharing options...
Jereme6655 Posted February 13, 2012 Report Share Posted February 13, 2012 carb slides the correct sides? how about doing a leak down and compression test? Quote Link to comment Share on other sites More sharing options...
350 screamer Posted February 13, 2012 Author Report Share Posted February 13, 2012 (edited) carb slides the correct sides? how about doing a leak down and compression test? its at 150 psi both sides im at 500-637 above sea level, with 4mm stroke and 5mm long rode, with reed spacers after the reeds to push back the carbs. the timeing is advanced +4. the pipes im running are FMF fattys and silencers. the cylinders are bored 20 thousands over. Edited February 13, 2012 by 350 screamer Quote Link to comment Share on other sites More sharing options...
guns4children Posted February 13, 2012 Report Share Posted February 13, 2012 spacer plate = no good Quote Link to comment Share on other sites More sharing options...
350 screamer Posted February 14, 2012 Author Report Share Posted February 14, 2012 spacer plate = no good Im puttin the 200 mains back in to see if she runns. maybe it needs to be smaller then a 280. Or since it runs better and actually fires in mid to high range rpms my pilot can go one size bigger? Quote Link to comment Share on other sites More sharing options...
