willardwright59 Posted February 11, 2012 Report Share Posted February 11, 2012 Should i bore my 28's since its free? My motor is: wisecos, trail port, cool head, 20cc domes, +4 timing, pc pipes, pods, 15/40 gearing, vf3's. Thanks Quote Link to comment Share on other sites More sharing options...
andrew3160 Posted February 11, 2012 Report Share Posted February 11, 2012 I think you will like the 28's just fine for Trails. You want to keep that bottom end. Quote Link to comment Share on other sites More sharing options...
willardwright59 Posted February 12, 2012 Author Report Share Posted February 12, 2012 I think you will like the 28's just fine for Trails. You want to keep that bottom end. Im going to get a dune play port bc i want the awesome power for when im ripping down the back roads. Which i do more than anything. Do carbs really give u more top end? Maby i should go to 30mm or.......? Any imput would be great Quote Link to comment Share on other sites More sharing options...
vulvafan537240 Posted February 12, 2012 Report Share Posted February 12, 2012 pro circuits are a low/mid pipe. i guess youll be going to a different pipe with the dune port? if so, bigger carbs will give more top end. i also think that 28's would be ideal for your current setup. Quote Link to comment Share on other sites More sharing options...
willardwright59 Posted February 12, 2012 Author Report Share Posted February 12, 2012 pro circuits are a low/mid pipe. i guess youll be going to a different pipe with the dune port? if so, bigger carbs will give more top end. i also think that 28's would be ideal for your current setup. I had a buddy who got 28's mikunis just like the ones i just bought last friday and he told me that his didnt do anything for his shee. Quote Link to comment Share on other sites More sharing options...
vulvafan537240 Posted February 12, 2012 Report Share Posted February 12, 2012 What was his setup? You don't want to go crazy big with your carbs while having pro circuits and a trail port. Quote Link to comment Share on other sites More sharing options...
Coupelx Posted February 12, 2012 Report Share Posted February 12, 2012 how are you boring them? stock carbs can be taken out to 28-28.5mm i think. Quote Link to comment Share on other sites More sharing options...
willardwright59 Posted February 13, 2012 Author Report Share Posted February 13, 2012 What was his setup? You don't want to go crazy big with your carbs while having pro circuits and a trail port. I believe his set up is toomey t-6 and vitos superstock pistons. Stock bore. And thats it. Maby got the head shaved. I know the bigger you go you loose bottom end. But i think boreing them to 30 would be a little of each. I see people have power jets. What do these do? Quote Link to comment Share on other sites More sharing options...
vulvafan537240 Posted February 13, 2012 Report Share Posted February 13, 2012 I would keep the 28's with the current setup and go with 33's when you get the dune port done and different pipes. Quote Link to comment Share on other sites More sharing options...
willardwright59 Posted February 13, 2012 Author Report Share Posted February 13, 2012 how are you boring them? stock carbs can be taken out to 28-28.5mm i think. These arent stock. Vm28's from mikuni. Quote Link to comment Share on other sites More sharing options...
willardwright59 Posted February 13, 2012 Author Report Share Posted February 13, 2012 I would keep the 28's with the current setup and go with 33's when you get the dune port done and different pipes. Sounds good. Would a power jet do me any good? Quote Link to comment Share on other sites More sharing options...
Coupelx Posted February 13, 2012 Report Share Posted February 13, 2012 Should i bore my 28's since its free? These arent stock. Vm28's from mikuni. Quote Link to comment Share on other sites More sharing options...
willardwright59 Posted February 13, 2012 Author Report Share Posted February 13, 2012 What are you comfused about? My posts make sence. Theres a site sponcor that has to do with selling carbs. These are MIKUNI carbs. They are not bored stockers. Stockers are vm26ss these are vm28ss. 2 totally different carbs. Quote Link to comment Share on other sites More sharing options...
So Cal Suspension Posted February 13, 2012 Report Share Posted February 13, 2012 Just out of curiosity, since I've wondered for a while. Who's bike are you describing in your signature? Quote Link to comment Share on other sites More sharing options...
willardwright59 Posted February 13, 2012 Author Report Share Posted February 13, 2012 Just out of curiosity, since I've wondered for a while. Who's bike are you describing in your signature? My banshee. I did a build a while back. Also posted here. "Really going to build it right" or something. My dad decided he wanted a rzr 900 and gave me his 98 banshee. So im doing a trail build. Quote Link to comment Share on other sites More sharing options...
