CruelSoul Posted February 7, 2012 Report Share Posted February 7, 2012 (edited) Ok so I just got my TORS kit installed so know those ugly ass boxes are gone, now it will not idle for nothing the adjustments ontop of the carb caps should I have to turn them out more to open the carbs to maybe help out for the idle or no, how much of the hole should I have filed off I just grinded them down flat should that be enough the screw if you look inside the carb is like this far sticking inside the carb [ ] about that much inside them marks is this enough? Now jetting help maybe thats an issue fmf requires this for what I have. My specs are this stock reeds with stock crossover bar,fmf powercore 2 silencers with fattys,190 degree raised ports, and Outerwears Airbox Lid with uni filter. Does this sound about right,or maybe I should goto a 27.5 pilot? I also live in Portage,PA not sure on the altitude where I live. Main Jet 260 Pilot Jet 30 Needle STOCK Needle Position 3RD Air Screw 1.5 Edited February 7, 2012 by CruelSoul Quote Link to comment Share on other sites More sharing options...
#1JUANstunna Posted February 7, 2012 Report Share Posted February 7, 2012 I ran a similar set up with 290 Mains, 27.5 pilots, needle in the middle, air screw 1.5 turns out. The adjusters on top of the carbs are for syncing the carbs, the screws on the side of the carb you should have drilled, and tapped is the idle adjustment. Quote Link to comment Share on other sites More sharing options...
CruelSoul Posted February 7, 2012 Author Report Share Posted February 7, 2012 Could that be my problem then I have no airleaks and a fresh rebuild aswell Quote Link to comment Share on other sites More sharing options...
So Cal Banshee Posted February 7, 2012 Report Share Posted February 7, 2012 Sounds like that's your problem. FMF website says 27.5 pilots, 280-300 mains depending on elevation, needle on middle clip to start. Im running 290\27.5\2 turns on my current setup with fattys at sea level, little fat but safe and not fouling plugs. Quote Link to comment Share on other sites More sharing options...
Man-O-Steele Posted February 7, 2012 Report Share Posted February 7, 2012 Did you unplug the part of the tors thats in the throttle housing? If thats still plugged in it wont idle. Quote Link to comment Share on other sites More sharing options...
CruelSoul Posted February 7, 2012 Author Report Share Posted February 7, 2012 (edited) Yes everything is disconnected even the black brain box. Edited February 7, 2012 by CruelSoul Quote Link to comment Share on other sites More sharing options...
Man-O-Steele Posted February 7, 2012 Report Share Posted February 7, 2012 Do you have the slides in the wrong side? When the carb is wide open you should see a little dot in the clear window on the slide housing. Quote Link to comment Share on other sites More sharing options...
CruelSoul Posted February 7, 2012 Author Report Share Posted February 7, 2012 (edited) How can u tell if the slides are in the wrong sides Edited February 7, 2012 by CruelSoul Quote Link to comment Share on other sites More sharing options...
#1JUANstunna Posted February 7, 2012 Report Share Posted February 7, 2012 There is a little window on the top right rear of the carb, on the part the slide fits in. When you open the slides all the way up (wot), you should see a dimple or dot in the window. Quote Link to comment Share on other sites More sharing options...
CruelSoul Posted February 7, 2012 Author Report Share Posted February 7, 2012 Ok ill check it out tomorrow,thanks. Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted February 7, 2012 Report Share Posted February 7, 2012 A sharp fucker looks to see that the cutaway is facing the air cleaner in case carbs are old as dirt and you cant see through the window. X-2 on jetting, start fat, work down. Slide idle stops need to be able to contact slide, might have to take more off carb body. Quote Link to comment Share on other sites More sharing options...
CruelSoul Posted February 7, 2012 Author Report Share Posted February 7, 2012 How far would you say the screw should sit inside the carb when screwed all the way in, I just don't wanna be taking off too much. Quote Link to comment Share on other sites More sharing options...
#1JUANstunna Posted February 7, 2012 Report Share Posted February 7, 2012 Hopefully a visual aid will help you Cruel! Quote Link to comment Share on other sites More sharing options...
CruelSoul Posted February 7, 2012 Author Report Share Posted February 7, 2012 Thanks, yeah mine will def. need to be grinded down some more cause mine is like that far in when it's all the way turned in. Quote Link to comment Share on other sites More sharing options...
