10mil topend, crank, cases
2sTrokeLove
  • 2 weeks later...
PM sent
I have a 10Mil drag ported cub built by FAST
10 mil twister crank
Noss cool head
Straight cut gears
Billet basket/ FAST clutch
direct drive lockup and cover
NEW oem flywheel and stator
timing plate
billet case saver
1-5 override
175 psi
ez drain cover, pancake bearing, billet impeller etc
Motor as all the goodies and is scary fast, was rocking it on a +4 swingarm
Couldnt believe this motor had loads and loads of bottom end with 39's and shearers
