looking for jetting recomendations
chetgoff
My current mods are
Drag Port from wild card.
35MM PWks with pods
cel needles.
head milled .20
64.5 bore
stock stroke
cases port matched.
timing +4
lightned flywheel.
nor tors or any junk.
elevation about 1200'
I just had it drag ported from wild card. It was ported before going there. The intakes are bigger then normal but this thing ripped before I had it ported more. He did not touch the intakes just transfsers and exhaust. The jetting before was DCK needle 68 pilots and 162 mains. it may have been a little on the rich side but it surre ran hard with no bog or hestitation.
Just looking for advice where to start at
everyone is stuck on the CEL needle and the fact is on a real dragported cylinder those needles can be too lean .most dragported motors i build come in around 52-55 pilot,dek or dgh needle,170 main jet but you got an answer from the man that designed those ports so i would listen to him.start rich it wont hurt
