DwnSouth Posted February 3, 2012 Report Share Posted February 3, 2012 now why would the 3's have a smaller opening than the 2's. Appears the small amount of material on the insert in the 3's can't be ported very much.... What do u guys do? Quote Link to comment Share on other sites More sharing options...
dcalsv02 Posted February 3, 2012 Report Share Posted February 3, 2012 I believe this is what you are looking for. http://67.199.65.66/cascade_innovations/newlook/store/store_View.cfm?STORE_AREA_ID=13&store_dept_id=83 Quote Link to comment Share on other sites More sharing options...
broncbob Posted February 3, 2012 Report Share Posted February 3, 2012 I don't really know, but my guess is velocity. I'm thinking the smaller opening is to speed up air flow, giving a slight over filling, or positive pressure VS static atmosphere pressure that the larger opening will give you. I may be way off though. Quote Link to comment Share on other sites More sharing options...
Coupelx Posted February 3, 2012 Report Share Posted February 3, 2012 I don't really know, but my guess is velocity. I'm thinking the smaller opening is to speed up air flow, giving a slight over filling, or positive pressure VS static atmosphere pressure that the larger opening will give you. I may be way off though. velocity was my guess too. Quote Link to comment Share on other sites More sharing options...
andrew3160 Posted February 3, 2012 Report Share Posted February 3, 2012 You can buy the retainers from FAST to open up the inlet of the VF3's. I believe you just modify the reeds your self. When I got my new intakes for my 35's I was told to match the inlet to the intake by using a dremel. Quote Link to comment Share on other sites More sharing options...
DwnSouth Posted February 3, 2012 Author Report Share Posted February 3, 2012 That's why i'm a member here. Lots of useless info... And sometimes good stuff too! Quote Link to comment Share on other sites More sharing options...
registered user Posted February 4, 2012 Report Share Posted February 4, 2012 check how well the manifold matches to the insert. i think your biggest concearn is if the insert hole is smaller than the manifold hole. i know the v3 dont match up for shit on some models. had to demel my cr500 v3 Quote Link to comment Share on other sites More sharing options...
