KarTek Posted February 3, 2012 Report Share Posted February 3, 2012 So, a search brings up too many responses for "leak". I just have to ask. On the carb, there appears to be both a carb vent/overflow and a bowl drain controlled by a small screw in the bottom of the bowl. There is a slow, steady leak from the bowl drain tube. I tried opening and then snugging down the screw but it won't quit leaking. Is there a replacement screw or seal available? So I have to replace the whole bowl? Thanks! Quote Link to comment Share on other sites More sharing options...
Starwriter Posted February 3, 2012 Report Share Posted February 3, 2012 That drain area also has a brass tube inside the bowl that goes above where the fuel level is when everything is working normal. When the float needle and seat leak, the fuel goes too high and overflows down the brass tube and out that hose by the drain screw. Pull the carb and check the float level. If it's correct, replace the float needle and seat. It's pretty common for them to go bad. Quote Link to comment Share on other sites More sharing options...
KarTek Posted February 3, 2012 Author Report Share Posted February 3, 2012 OK, I see. So, if the needle and seat are leaking, the fuel will still come out of the drain hose but it will never make it high enough to flow out of the vent hose. Quote Link to comment Share on other sites More sharing options...
Starwriter Posted February 3, 2012 Report Share Posted February 3, 2012 OK, I see. So, if the needle and seat are leaking, the fuel will still come out of the drain hose but it will never make it high enough to flow out of the vent hose. Correct-a-mundo Quote Link to comment Share on other sites More sharing options...
vulvafan537240 Posted February 3, 2012 Report Share Posted February 3, 2012 Correct-a-mundo tell me more about the female in your avatar Quote Link to comment Share on other sites More sharing options...
Starwriter Posted February 3, 2012 Report Share Posted February 3, 2012 tell me more about the female in your avatar Just some big titty girl pic I found on the internet. Quote Link to comment Share on other sites More sharing options...
Wisconsinz Posted February 4, 2012 Report Share Posted February 4, 2012 Just some big titty girl pic I found on the internet. Well played sir, well palyed... Quote Link to comment Share on other sites More sharing options...
