Banshee starts then dies
10milmike
OK, Guys I am lost. My cheetah fires first kick then dies about 2 sec later, I check the spark, I have spark, new coil, new reeds, so what would cause this? I even tested the cdi from the other banshee i have, and it still does the same thing. Starts first kick then dies 2 sec later, I took off the head and looked at the pistons, they look fine, Top end is only a year old, with 155 psi in each jug. so what could this be?????
Was the machine running well and then it started doing this? If so then the answer is electrical. Especially if it will not even stay running with the choke on
Adam
I know its electrical, I tryed my CDI box from my other Banshee, and stator, still does the same thing. I had the wire harness redone, that is the only thing I have not checked yet.
  • 9 years later...
