spark plugs
I usually run NGK BR8EIX's ( or what ever the Iridium Plugs are). Same heat range as stock as well.
I have also run NGK BPR8ES's they are the same heat range as stock but they have a Projected tip that hangs down a little in to the combution chamber. That way they are not recessed in to the head.
